Air Hissing Sound On Bumps
Old Jul 18, 2023 | 12:13 AM
S550TK's Avatar
08' S550, 19' GLS450
When I go over bumps, the front drivers wheel makes a hissing sound. It sounds like air brakes on a bus or truck. Is my airmatic suspension starting to go out? What is the solution? I have put a video as well.
Any help is appreciated.
File Type: mov
Old Jul 18, 2023 | 05:52 AM
BOTUS's Avatar
S500
not enough info - could be anything
might be a bit of undertray dragging on the ground
unlikely but air coming out of the tyre
or might be suspension related, you can get really odd sounds from suspension or ARB bushes but it may be a damaged airbag releasing air as it moves - never read on here but fairly normal on E class estates that the air bags self seal as the weight drops back on them... try using the button on the dash to raise to full height - turn off the engine and see if trying to rock the car gets anywhere...
the other thing, usually a leaking system will drop a lot over night - in the end you'll wear out the compressor - suspension level sensor link rods seize and should be part of a maint programme
>100k and 15 years the air bags will be towards end of life
Old Jul 18, 2023 | 06:30 AM
Dudes_07's Avatar
2007 S 550
Definitely your air strut, just replaced my driver side 3 months ago and the passenger side last week. For what it is worth I replaced mine with suncors since mine is not 4matic, the price was right and so far so good.
Old Jul 18, 2023 | 08:43 AM
COUPCONNOISSEUR's Avatar
2010 CL550
If the vehicle is holding normal ride height and you hear air escaping, it can also be a broken air reservoir/fitting..it’s located on the driver side, directly below the headlight. As they age, they tend to crack. When my CL was hissing air, it looked perfectly normal, but the air hose was cracked at the fitting to the tank
Old Sep 17, 2023 | 02:22 AM
S550TK's Avatar
It ended up being the air strut. Just wanted to let everyone know for future reference if someone has this problem.
Old Sep 17, 2023 | 10:57 AM
Senecat's Avatar
1983 Nissan Shltbox
So you replaced it?
Old Sep 17, 2023 | 11:34 AM
BOTUS's Avatar
S500
on all other older mercs people play with just the air bags - why don't we see that on the 221s - the dampers on mine have never done any work - but at the back, one of the gaiters has fallen to bits and the car would likely benefit from swapping a sad stiff air bag for nice air tight soft supple ones ?
Old Sep 17, 2023 | 12:41 PM
S550TK's Avatar
Yes, I replaced it with a Bilstein assembly.
Old Sep 17, 2023 | 12:42 PM
S550TK's Avatar
Originally Posted by Senecat
So you replaced it?
Old Sep 18, 2023 | 08:11 AM
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
I always assumed these have air struts at all 4 corners to mimic the ABC setup (as opposed to the separate air spring in the rear on the E-class, for example). I've never heard of anyone separately servicing the air spring on the front strut of an E-class.
Old Sep 18, 2023 | 08:28 AM
BOTUS's Avatar
S500
they do make them....
https://www.mercedesmedic.com/merced...placement-diy/
mind u at this price you get new dampers and 2 year warranty ?
https://www.carairsprings.co.uk/merc...21-suspension/
Old Sep 18, 2023 | 08:31 AM
BOTUS's Avatar
S500
£50 each and 36 postage
https://www.aliexpress.com/item/32893832529.html
or a UK supplier on a deal £137
https://aerosus.co.uk/mercedes/s-cla...-or-right.html
Our air springs are an economical solution to repair your air suspension strut and are designed to ensure easy replacement without special mounting tools. If your shock absorbers are still in good condition, replacing only the air springs is a more budget-friendly option of fixing your air supension struts.
Aerosus air springs are made of high-quality elastomer materials and covered by a 2-year limited warranty and a 30-day money-back guarantee. The rings on the air springs are crimped using a special technology for dependable operation and leak-free performance.
Our suspension air bags keep your vehicle level, even when carrying an uneven load. This means more effective handling and braking even in tough road and heavily loaded conditions.
Aerosus air springs are known for their superior dynamic properties as well as their long life and reliable durability.
Features
OE-quality
Maximum ride comfort
Security and durability
Safe load carrying capacity and stability
High-quality raw materials
Easy installation without special mounting tool
Thousands of satisfied customers worldwide
  • A-221-320-93-13
  • A-221-320-49-13
  • 221-320-93-13
  • A-221-320-93-13-89
  • A-221-320-93-13-80
  • A-221-320-93-13-00
  • 221-320-49-13
  • 221-320-93-13-89
  • 221-320-93-13-80
Old Sep 18, 2023 | 10:26 AM
kevm14's Avatar
My thought is if the thing has enough wear/age on it for the air bag to fail, replacing the whole thing is not a bad idea (just not with aftermarket).
Old Sep 18, 2023 | 10:37 AM
BOTUS's Avatar
S500
AT Parts Germany GmbH is the company that stands behind AEROSUS – a leading brand in the air suspension market. Based in Cologne, Germany,
I wouldn't say Merc parts are any good.... I wonder if these are as good if not better than OEM ???
Old Sep 18, 2023 | 10:45 AM
kevm14's Avatar
No idea - but Euro/UK parts supply chains (and prices) can be pretty different from the US, which can really skew the technical recommendation.
