Passenger side cylinders misfire
The CP’s from MB have a finite life. The CP’s from Clark have a longer finite life due to upgraded components and of course keep the oil out of spark plug wells.
The VT, Boost Box has upgraded industrial components, fused, and located in a cooler spot.
If you can muster up the money, call Clark Rupp, do the work yourself, make a nice sandwich:
Remove old left/right coil packs.
Remove oil soaked spark plugs
Install new valve cover gaskets and tighten spline bolts to spec.
Clean spark plug wells with Egyptian cotton towels.
Install new spark plugs, verify gap, and torque to spec. Anti seize goop is optional.
Install new refurbished left/right coil packs from Clark.
Remove old VT on top of engine, and replace with the brand new Boost Box from Clark and mount it on the much cooler temperature firewall out of the way of the left/right windshield wiper armatures.
The engine will run like new for 70k miles or more.
Johnny
until I studied his video I didn't understand the points he's making - but I was very well aware - VIRTUALLY ALL V12 OWNERS GET A MISFIRE, BUY A NEW COIL PACK AND BLOW ITS BRAINS OUT WITHIN THE WEEK - as these packs are so costly its not a good way forward for most owners
https://mbworld.org/forums/s-class-w...ml#post8755102
last night spent 2 hours watching that guys videos of what goes wrong...
the iron core inside each of the 24 OEM coil sticks breakdowns with time (not mileage), often randomly with any of the 24 coil sticks dying around the 11 year mark, as this fails the windings short and can send voltage spikes round the system that often blows the brains out of the voltage transformer and or the whole banks coil pack. So one ageing coil stick starting to breakdown starts a chain of events introducing the possibility of three major issues
its quite an odd get up - rather than a coil on top of each plug with its own 12v power supply like the V8s get - the V12 mercs have "two coils sticks per cyl" that swap duties back and forth each spark. One spark its being a 180v main coil, then next spark its an emission clean up spark coming fractionally late to the party as a 23v coil. To achieve the magic spark fest, each bank of 12 coil sticks are part of a complex electronic circuit board making one bank's (6 cyls) coil pack.
so the issue usually starts with an owner exercising the car, which makes life harder for any of the coils, and that often brings in a random one cyl coil stick failure. But that can blow the whole coil packs circuit board taking out multiple cyls on one bank. And or blowing the brains in the separate voltage transformer - this VT is what gets the required 180v / 23v power supply change. Thus one coil stick starting to age, often ends up giving a two or three cyl misfire as the voltage transformer gets damaged.
However even with good coil packs the voltage transformer can get cooked to death from normal engine heat over time, and this can bring down the whole set up in a costly disaster
Usual scenario, one coil stick ageing can bring down the whole lot, and even when the whole 12 stick coil pack on one bank is replaced, a damaged VT (caused as the first stick died) often ends up killing the replacement coil pack and its a circle of expensive hell and head scratching
so the fix is three opportunities for a mortgage
remove your voltage transformer (VT) today and exchange it for one of his upgraded longer lasting overhauled VT OEM boxes now with two fuses you can replace - to stop a complaining coil stick sending back a spike and blowing up the Merc OEM $800 VT unit
then if brave and stupid you can buy a faulty coil stick on ebay and likely trash the whole bank trying to fit one new budget fake coil stick for a cyl you identify as playing up, OR swap out the whole group of coil sticks (made in house via china) with his upgraded coil pack where all sticks have been replaced and re-soldered carefully to the refreshed circuit board
alternate option replace the OEM VT and fit his upgraded remote located (for a cooler location) more sophisticated VT box which I guess can cope in solid state with coil sticks throwing teddies and you don't need to play swapping fuses in the rain at the side of the road...
Allegedly the VT, both coil packs, and a set of 24 spark plugs - at circa $7k - should be swapped around the 70k miles and or every 7 year mark
https://www.v12icpack.com/
Glad to see your reasoned decision was correct…
Regards… Mark
