w221 stock airmatic reset
Did you try cycling through raised mode and ride height using the dash button?
Why did you replace the strut? (How did you diagnose? Are you sure it was the strut and not the valve block?)
If you want to go the cheaper route, you can get a bottle of leak detector spray from Amazon. You just spray it on every line, connector, and component and look for bubbles. You might get lucky.
the two fronts are easy - the one rear sensor above the park brake module is a very unpleasant task
