w221 Rough Idle
decent diagnostic kit will tell you EXACTLY which cyl is playing up - YOU MUST NOT DRIVE or ALLOW TO RUN LIKE THIS - IT WILL RUIN THE CATS AND NOT MANY MILES LATER TRASH THE ENGINE !!!
if you run android this will do it - https://play.google.com/store/apps/d...anmaster&hl=en you will ALSO need a competent OBD2 dongle - don't buy the cheapest on ebay - u will buy 5 or 6 before getting one that almost functions... ones worth owning are $40 to $70
vlinker have started making decent dongles that cope with much of the modern world - and ALWAYS load the latest firmware to the dongle - they discover every few months yet more tricks and cheats the manu build in to stop proper communication.... https://www.vgatemall.com/products-detail/i-52/ that one will do fords correctly but then not GM... they only just worked out the one you need to do Ford's correctly needs to fake 18V (FEPS) - either of these get you full BM capability (so you can code all the toys till it looks like a 3 year old played) but few will do GM Single wire CAN (that no one else bothered to use) - vlinker do a MC version to play on bikes correctly that also does GM https://www.vgatemall.com/products-detail/i-5/ )
One day when they work out how we'll be able to buy just one and it will do everything - but today there's isn't one out there - unless you go the $2000 route and even then its a lie....
the set up above (a decent app and a decent dongle) should be in the pocket of ANYONE ever starting ANY modern car or bike at ANY time.... they are that ALL that badly made - today its madness not to have it with you 24 7
