Custom Wheels Offset Input Needed - BCForge on a W221 S65
- I'm told my vehicle is lowered (see pictures), so please keep that in mind for rubbing
- I'd like to put 285 or 295 wheels on the rear tires, but it's really not necessary
- OEM brakes
- Whatever wheel/tire combo is purchase needs to have the tire stick out "fatter" than the rim, like in the factory combo. Metal cannot stick out past the rubber; doesn't look right to me.
Stock wheel specs:
255/35ZR20 - 8.5Jx20 ET43
275/35ZR20 - 9.5Jx20 ET43
Recommended from BC Forge:
255/35/R20 - 9.0x20 ET35
295/30R20 - 10.5x20 ET40
So given all this, what would the experts recommend? Do people ever order custom wheels in the factory specs? Also interested to know if I'd care about 60-degree conical lug seats vs. factory lug seats. Would love to hear some thoughts before I drop almost 5k on new rims. Thank you!
Lastly, MAKE SURE the wheels you chose are built to handle the weight of your car as aftermarket wheels on these heavy cars are VERY likely to get bent when hitting potholes or poor surfaces. That would be a terrible waste of money. I would chose REPUTABLE ONE PIECE FORGED wheels
if I were you. OEM wheels are built like a tank for a reason. Wheel vendors will tell you their wheels will FIT on your car but holding them down to warranty an inferior product resulting in a bent rim from a pot hole that the OEM would eat for breakfast may be very disappointing and costly.
BCForge states that they build these specifically to the vehicle so hopefully my woes go away. I'm actually replacing my OEMs because I've gotten two small cracks in them since ownership, which have to be welded back together. I've done a lot of research and their wheels seem to get solid reviews, but if anyone knows otherwise, please give me a shout!
Non run flats have sidewalls that are not as stiff .. the ride will improve..which will fit your needed function and comfort.
IMHO dropping 5k on rims that arent as heavily built as the OEM is gonna be counter productive.
My suggestion is to find non run flat tires in stock size with a rim protector molded in to protect the rim edge. If you still want to fit wider rims, then get rid of the dropped suspension, use the fronts 255/35/20 with the rim protector and find full forged rims not flow formed ( barrel rolled ) ones.
Here is a link to a tire/wheel fitment calculator: https://www.willtheyfit.com/
That should help with your decision. Let us know what you decide.
I will check into your tool here this evening. Are you recommending that if I go aftermarket to just stay with stock fitment? I'm honestly fine with that if it will yield better results; I think the stock offsets look fine.
I believe they have ONE PIECE MONOBLOCK FORGED wheels correct???
indicates that a one piece monoblock forged wheel is extremely durable, desirable, and highly suggested for these heavy w221 s550 chassis to apparently exponentially decrease the chance of bending a rim. I personally don't have the coin to put 12k-15k wheels on my car but if money was no object I would. Nothing is guaranteed except death and paying taxes so choose your wheel/tire combo of your choice for your beautiful car and go with it.
Hope you get it resolved to your satisfaction.
PS: inflate to the lower f/r psi specification in the fuel door, that will also help with the ride and your back LOL
