2013 to 2017 Engine Swap Questions!!!
Old Jul 11, 2024 | 02:18 AM
51mike's Avatar
2006 ML500
I have 2013 s550 with 108k on it cylinder 4 scoring and knocking. I found 2017 GLS 550 with low miles. I wanted your help if I can swap this engine on my car? Is it direct fit or can not be done.. your input is appreciated. If this don't work which car model engine fits? 4matic if I change the oil pan would it work?
Old Jul 11, 2024 | 01:30 PM
BOTUS's Avatar
S500
check parts catalogue - if most of the main bits fit u have a chance... but in all those years loads of ancillary castings / mounting and engine management bits will have evolved
in the days of CAD and design to fail, they push all the aggro of the supply chain on to third parties and change everything every other day - its not a small block Chevy that's been in production for 60 years - these days its more like 6 minutes...
Old Jul 11, 2024 | 02:14 PM
vettebk's Avatar
2007 S600, 2007 Chrysler 300 SRT8, 2000 C5 Corvette, 2017 Mustang GT, 2023 300C, and a 2019 Lincoln
And I don't think an LS engine will fit either.....
I could be wrong.
Old Jul 12, 2024 | 06:34 AM
Jaap's Avatar
2006 W221 S500L M273
Similar threads worth reading:
https://mbworld.org/forums/s-class-w...-look-out.html
https://mbworld.org/forums/s-class-w...-possible.html
Old Jul 12, 2024 | 08:42 AM
Ultrakla$$ic's Avatar
Benz w221 s550
I could be wrong.
you can MAKE an LS engine "fit" anything....
On that note, interested to see how this swap is going to turn out. I wish the cylinders could be rehoned or bored in our blocks.
Old Jul 12, 2024 | 04:40 PM
BOTUS's Avatar
S500
when u bend a rod on an AMG as you will - pikey's do a cast iron liner bodge up (then pass it on - coz a new block is $36k fitted)
Old Jul 12, 2024 | 04:50 PM
BOTUS's Avatar
S500
just had to do it....
