2007 s550 4 matic stop lamp switch
Does anyone know part number for this . Have abs esp light on intermittent when I back up and depress brake pedal , eventually the abs /esp message clears
check and replace ABS wheel speed sensors.....
Abs sensor
thanks have to figure out which sensor is bad the brakes in the back are low so I may try replacing both back first I don’t have a scanner to see one and the local AutoZone no codes came up and only happened sometimes when I back up and depress the brake pedal fast once the car shut off and started again after a mile it goes off . I’m also wondering if the low pads in the back are causing the light to come on as well, etc code d408 came up , perhaps related to rear sensors , don’t know that for sure though
the pad sensor error will show in the manual... ???
wheel speed sensor is on the back side of each wheel and on the 221 fail all the time - really easy to DIY 20min once you have the road wheel off... could try aftermarket ones the OEM ones are pathetic junk and silly money... if they come up faulty do both on same axle... rear normally go first
