How do I put gear oil in the front diff case!??
However, it has no published drain interval for changing the fluid.
When I did it at 10 years, 75K miles, the fluid came out appearing brand new.
There is little to no reason for fluid to be contaminated unless the diffs go under water. Motor oil is contaminated by combustion products blowing by piston rings. Nothing similar happens with gearboxes.
The combination of petroleum chemists and mechanical engineers due to their education, testing, and experience have a pretty good idea what's required as regards oil breakdown. Your mechanic is not qualified to advise ... otherwise he'd have more education and a better job.
Recall that maintenance of German cars is expected to be performed by trained professionals who must inspect everything. This is yearly or every 10K miles. If something unusual has occurred to create fluid loss they will find it and advise. CV joints really aren't lifetime components, so when one fails its an opportunity to renew diff oil.
I was into BMWs when they changed from a defined interval to lifetime fill, the fluid didn't change spec. There is an old school bmw Maintenance document from roundel that the author explicitly states isn't his schedule but just the old bmw schedule. I assume the same thing happened at mercedes and was accelerated when maintenance was included with purchase.
Fluids break down. Coolant, engine oil (10,000 mile interval is fine if you intend to trade it off in 30,000 miles), transmission oil, ABC/MBC, power steering, brake fluid, all gear oils.
Your car, your choice. I choose to renew fluids more often and have never had a transmission, differential, power steering, brake hydraulic, ABC failure that could be blamed on quality of the fluids involved. I sure have seen the results of ‘deferred maintenance’ in clients cars.
Looking down your nose at mechanics doesn’t say anything positive of you.
OTOH, my neighbor is a retired (only officially) mechanic, and he's one of the smartest guys I've ever met. His shop is always filled with repair projects ranging from chainsaws to heavy industrial machinery. He can fix it all in the time I'd be trying to figure out which wrench to use. I never hesitate to ask him for advice, despite my "superior education".
