W221 2007 S550 Gas Gauge, signal lights, lights flicker
Old Nov 1, 2024 | 07:36 PM
jburn7777's Avatar
W221 2007 s550 - Gas gauge works when car is turned on then immediately stops working at the same time the signal lights stop working and the inside dashboard and door lights flicker.
Old Nov 2, 2024 | 06:18 AM
Jaap's Avatar
2006 W221 S500L M273
Start with the obvious, basic steps:
Check both batteries
What is the voltage of the big battery in the trunk before and after this happens?
Scan the car for codes with a scanner that can see all the modules (like Xentry)
