W221 headlight retrofit with OEM SAM - 2024
Old Nov 10, 2024 | 06:38 PM
Plato's Avatar
W221 S500
Originally Posted by trigital
Of course, I can post here schematics for facelift headlights, but this schematics will work with the facelift SAM ...without adaptor if adaptor is not only for IHC. Do you have any link for your adaptor?
I have connection schematics from WIS and I have linked outputs from old SAM to facelift headlights... I sent a picture above how exactly it was done. Also additional wiring was added when I had facelift SAM but now it's not really needed as I didn't mention any difference when I disconnect it.
If you mean you can read logic boards schematics and tell me what to change I can do that.
I still want use old SAM. Is it possible to have it work with old SAM?
CAN module is discontinued unfortunately so it's not available online. But I can share it's connected and what changes was done inside the SAM:
CAN module work as 'man-in-the-middle' method and it converts CAN signals between SAM and XALWA.
Old Nov 10, 2024 | 06:46 PM
trigital's Avatar
W213 All-terrain
https://www.ckmcardes********/s-clas...sen-adapterkit
Here, in the EU this solution is named "Chinese solution". If only position/parking lights not working, you can install resistors.
It's far too complicated ( for me ) and of course far beyond any safety. All that is based on the folklore regarding " coding is hard".
Sorry, I can help only if you install the facelift SAM.
Old Nov 10, 2024 | 06:56 PM
Plato's Avatar
W221 S500
Could you please share coding instructions to have facelift SAM properly work with old car' batteries? If it's smth really realistic and relevant I would revert back to facelift SAM (I still have it and all lighting works ok when it's installed).
1. Batteries are different thus different protocols to operate with them: 35Ah vs 95Ah AGM under the hood, 95Ah AGM vs none in the trunk, and none vs ~10Ah in the dashboard).
2. Consumer shutoff doesn't work properly (lamps in the doors and cigarette lighter relays are turn on and off very quickly (like a strobe) instead of shut off.
3. A constant errors about F32k2 quiescent current relay
PS: For parking lights if resistors can solve it why coding can't do that?
Old Nov 10, 2024 | 07:26 PM
trigital's Avatar
W213 All-terrain
There is a domain named BMS - battery management bla, bla, where you can code the battery. Just one relay from consumer shout off will strobe a little but will stop every time with no problems.
Quiescent current can be coded as well from battery sensor domain
The resistor is needed on old SAM because there is no option for coding the positions.
Old Nov 10, 2024 | 07:28 PM
Plato's Avatar
W221 S500
@trigital You are referring to safety and you are 100% right. But by installing facelift SAM you solve headlights but you have dozes of other issues because that new SAM designed for a newer car and there is much more things to care safety in. I have listed several issues above. If you know how to solve all of them not just these three I will move back to facelift SAM and code it properly.
Old Nov 10, 2024 | 07:37 PM
Plato's Avatar
W221 S500
I saw BMS under SAM in DAS - it's not as a separate module and there is no way code there smth. Or do you need coding trough DTS Monaco? Or could you please tell me how exactly it can be coded?
Just one relay from consumer shout off will strobe a little but will stop every time with no problems..
Two of the will strobe in rear SAM + lights in doors and trunk... I had that with my facelifit SAM
Could you please tell me how exactly it can be coded?
Do you remember what bulb was in 2008 W221 as parking light so I can find a proper resistance to try?
PS (IMPORTANT): If I solve parking lights is it possible to code DLR to work properly? Since old car also had DLR but different type.
Old Nov 10, 2024 | 07:45 PM
  #32
trigital's Avatar
W213 All-terrain
With old SAM you will need resistors and the DRL will never work as DRL, it can only work as Fog with resistors as well ( why you keep saying DLR, I am curious). Any function with resistors is not safe and may be not legal as well.
I never installed resistors so I can't tell you the values, but any Chinese installer should know.
Under PWM voltage the resistor will be very hot
About coding, is always related to the SW and HW. It's not a universal solution.
If you install facelift SAM, I can show you how to save the coding ( with Vediamo or DTS Monaco software) in such a way to see the variants.
  #33
Plato's Avatar
W221 S500
Also wondering is resistor will solve parking lights why there is no errors in DAS or on screen...?? When I activate paring light in XALWA errors appear... But when I turn light on it doesn't
Old Nov 10, 2024 | 07:49 PM
  #34
trigital's Avatar
W213 All-terrain
Wrong approach.... wrong coding, the definition of non-safety. As in 99.99% of cases the lights will lit on a mountain road with hairpin serpentines....
Old Nov 10, 2024 | 07:54 PM
  #35
Plato's Avatar
W221 S500
Thank you for your time. Much appreciated for this continued and meaningful conversation.
But what about those ILS functions what was available in old headlights and those available in new (like adaptive fog light, highway light, etc). Do you mean you can also code it so I don't need my CAN module in fact if I install facelift SAM?
Old Nov 10, 2024 | 07:56 PM
  #36
trigital's Avatar
W213 All-terrain
Yes, new SAM, correct wiring and that's all.
Old Nov 10, 2024 | 08:00 PM
  #37
Plato's Avatar
W221 S500
Also I read somewhere on forum for the scenario with facelift SAM I also need a facelift CWG. Is it true?
Old Nov 10, 2024 | 08:02 PM
  #38
trigital's Avatar
W213 All-terrain
No, the CGW is not needed to be exchanged.
Old Nov 10, 2024 | 08:07 PM
  #39
Plato's Avatar
W221 S500
Ok I messaged you in PM
Old Nov 11, 2024 | 04:25 AM
  #40
BOTUS's Avatar
S500
I have a specialist near me that has only done Merc high end retrofits for the last 20 years - many times he specifically told me he has done lots of facelift headlight conversions to old 221s and he told me (and he showed me a CGW he keeps just for this process), he fits a later gateway pulls in the files and SCNs the later options to early cars - then refits the original CGW - maybe he can do it this way as he has paid online Xentry....
Old Nov 11, 2024 | 05:02 AM
  #41
trigital's Avatar
W213 All-terrain
He do that for his online system, this way the MB server thought that a newer car ( with another VIN);is connected and he can code online the old car with the new VIN options. That's the solution when you can't do coding. As there is a lot of options that can differ
Old Nov 29, 2024 | 08:07 PM
  #42
AL5461's Avatar
W221 S500
Using DAS offline you can do it yourself. Obviously if you make a mess then it gets expensive, but it's not impossible.
Old Dec 5, 2024 | 12:34 PM
  #43
kotgacek's Avatar
I made hundreds of headlights retrofit on w221.
Only need facelift SAM ( the one with plastic cover) and the wiring accordingly with the facelift schematics, no any adapters needed.
All functions works, ILS, DRL, even the Battery management can be coded.
There are several wires that need to be added and most of them need to be re-routed on SAM side.to have the facelift configuration.
Hello, iam doing conversion, can u share what need to cross in sam front? I got facelift sam f. Best regards
Old Dec 5, 2024 | 01:30 PM
  #44
trigital's Avatar
W213 All-terrain
You will need to re-route some wires and to add two wires, exactly as schematics on facelift 221.
Some knowledge is required to find and especially to understand WIS schematics
Old Dec 5, 2024 | 01:32 PM
  #45
kotgacek's Avatar
I got wis, also prefer to use etm in wis classic. But for facelift and prelift its same scheme :/
Old Dec 5, 2024 | 02:55 PM
  #46
trigital's Avatar
W213 All-terrain
Then you can start with a much simpler retrofit.
Old Dec 5, 2024 | 03:06 PM
  #47
kotgacek's Avatar
Can u share number of dokuments from wis? Just this.
Old Dec 6, 2024 | 01:47 PM
  #48
Plato's Avatar
W221 S500
Left before 2009
Left before 2009
Left after 2009
Left after 2009
Right before 2009
Right before 2009
Right after 2009
Right after 2009
Old Dec 6, 2024 | 01:51 PM
  #49
Plato's Avatar
W221 S500
pe82.10-p-2000-97saa
pe82.10-p-2000-97sab
Old Dec 8, 2024 | 07:20 AM
  #50
Plato's Avatar
W221 S500
@BOTUS @trigital or anyone else could you please disclose what dose these settings in retrofit SAM mean? What exactly they enable/disable?
Kurvenlicht Substitution
Kurvenlicht Substitution Nebelscheinwerfer
Retriggerzeit Scheinwerferaufschaltung
Ersatzlichtfunktion aktiv
