Any fixing method
Old Dec 6, 2024 | 12:01 PM
gmanmiki's Avatar
Any fixing method
I have a 2011 S350CDI with 100k miles that recently developed an annoying habit of occasionally not starting.
Symptoms:
- When key turned, dashboard shows ESP and run flat inoperative in yellow. No engine checklights though. Reading errors only shows P0113 Intake Air Temperature Sensor and P00AD (again air intake sensor) errors which are not present at all when the car starts ok.
- When the car doesnt start, the pre-ignition glow sign doesnt show up on the dashboars. Also spotted that the car's air suspension compressor doesnt start the hissing sound that's usual when starting the car.
- Engine can not be started, not even a cough. Waiting 10 minutes, locking/opening, once a battery hard reset seems to make it work. After it starts, everything is fine and drives perfectly, no errors can be read from the car.
- Feels like happens more frequently at cold starts, never happened if car only switched off for very short period (less than 2 minutes), but did happen a few times when stopping at a resting place on a highway for approx 10 minutes.
So far MB dealer only replaced battery - guess they had no clue. Issues still came back.
Any help much appreciated!
Old Dec 6, 2024 | 12:52 PM
BOTUS's Avatar
S500
with these "P0113 Intake Air Temperature Sensor and P00AD (again air intake sensor) " it runs very close to symptoms all caught up in a bit of mischief they had "accidentally" left in the engine ECU software
I would certainly check if there are updates waiting to go on the car
then if that isn't the issue work through other drivers that can give these faults
if a car is really playing up and you have faults showing up in diagnostics that are likely related - you can't magic them away - you have to find the cause and resolve them
