Abs help
Old Dec 9, 2024 | 12:15 PM
bobdog231's Avatar
2009 mercedes s 550
Abs help
I've had the ABS ESP light on on my 2009 S550 Mercedes Benz for a while now I replaced all ABS speed sensors and now the car says no speed sensors detected any help from the community would be very appreciated
Old Dec 9, 2024 | 12:31 PM
Jaap's Avatar
2006 W221 S500L M273
Originally Posted by bobdog231
... the car says no speed sensors detected ...
Where does it say that?
In the cluster or on a code reader?
Are the ABS and ESP lights still on?
Old Dec 9, 2024 | 01:41 PM
bobdog231's Avatar
2009 mercedes s 550
On code reader
yes lights are still on
Old Dec 9, 2024 | 02:55 PM
BOTUS's Avatar
S500
light or cluster display message.... and what colour
Old Dec 9, 2024 | 08:29 PM
bobdog231's Avatar
2009 mercedes s 550
Abs sign on plus esp inoperative on dashboard
abs light, esp inoperative is cluster and the color is yellow
Old Dec 10, 2024 | 04:56 AM
BOTUS's Avatar
S500
you can't guess on modern cars - you'll need to use reasonable diagnostics...
first thing I'd do is view all four wheel sensors readings as its driven down the road - only need to go 100 yards - if on or more are being odd check the parts you replaced - rears die frequently
see what else the car is moaning about wipe and recheck after a short drive
ABS modules dying is sadly very normal on motor cars, although Merc oddly seems less afflicted than the junk most German crooks buy - with VAG & BMW etc. buying ones deliberately designed to cause customer problems
Old Dec 10, 2024 | 06:27 AM
trigital's Avatar
W213 All-terrain
Why do you change all ABS speed sensors?
Old Dec 10, 2024 | 07:21 AM
Jaap's Avatar
On code reader
This does not make a lot of sense.
What is the exact full text from the code reader?
