To those of you with strong W221's, passing preparations
To those of you with the strong W221's, i.e. the 500's, 63's, 65's, 600's etc..
When you're thinking about passing on a 2 lane road, and there are 5-6 cars you have to pass at the same time, do you ever have to get prepared in advance, i.e. switch to M and downshift to get in the power band in advance, and then launch, or do you just put the foot and and it goes?
I have an M272E35 S350 and the *rare* times I have to pass someone I always prepare in advance, M, get in gear, and then go.
I have a vintage BMW V12 where I don't have to do anything, I just point and click and it just happens before you even realized it.
Just wondering if this is a 7G thing, or if it's a M272 case.. If I need to do a maneuver like this by the time the car realize it's "time to move fast" it takes a second to break out of comfort 'slow roll' mode into 'takeoff' mode.
With my 2010 E550 I tried it a couple times and it is scary what happens with it. There is so much power that it really scared me.so I stopped doing it. Now I just step on the pedal and there is plenty of power this way too.
With my 2012 S550 with the twin turbo engine I have not even tried as it has so much power, especially torque, that with just stepping on it, it kicks the slip control on and the power cannot even be used because of it. Would need some sort of special grip race tires to be able to use all power the car has to offer.
More frustrating is that if you do pre-select a lower gear with the paddles (wirtout switching to M, just pulling the left paddle once or twice), it will not stay in that gear when you quickly press the accelerator, it will still hesitate and change to an even higher gear. Aaaaarrgghh! Stupid thing!
thus the engine and gears only work together properly at 4k rpm (on a petrol engine) - so if the space is 10 car lengths and you are trying to do 6 cars - Yes you need to wind it up first - I often drop 3 gears if I need to press on
I posted before ages back
real ones
https://en.wikipedia.org/wiki/Rolls-Royce_Limited
BMW freaky looking tat
https://en.wikipedia.org/wiki/Rolls-Royce_Motor_Cars
Audi's spelt with a B
https://en.wikipedia.org/wiki/Bentley
In 1997 BMW started taking an interest in RR and they started supplying their joke utterly gutless V8s engines, almost killing the Brand overnight - having ruined the company, in 1998 they let VAG (VW) make a massive financial blunder (at the time believed to be a stroke of genius) and VW bought the headache of the dying business with only the gutless BMW engines in the model range. In the midst of the carnage BMW popped up and mentioned the small print - where they did the dirty and got the RR brand without a headache. Leaving VW with just the Bentley brand, a tired factory, and a model range of even uglier 45 year Shadow's now running 4Ltr moped engines
Owners of the previously torquey RR and Bentley 6.75ltr L410 V8s couldn't cope with the 4 ltr BMW engine'd models of the late 1990's. Owners couldn't understand why nothing happened when you put your foot on the throttle of these lawn mower cars from the Germans. The sales collapse quickly saw VW ditch the german engines and put a real one back in (which stayed till 2020) fixing the power situation using the original V8 (an engine in development from 1952 until emissions killed it off the last real engine'd Bentley’s in 2020).
The idea one wanted to wait half an hour for a gearbox to downshift at least twice, and then wait for the revs to pick up (and make uncouth noises) before anything happened, was an anathema to British drivers. They were used to pushing the throttle peddle down 1/2 an inch and being in the next county within a few seconds, without any additional noise...
After 20 years learning, VW Bentley's and BMW RR's now have waftability built in to the power train - rather then the Germanic racket of revs and nothing happening - I presume lots of Boost and far fewer gear changes - whereas real German Brands once they've changed down 4 gears seem fractionally quicker - coz still setup for road rage on the Autobahns - after all, you've got to pull out in front of someone going much faster the second that first flash of the left indicator glimmers - how else can you get the brakes as hot and bothered as the appalling drivers
real ones
In 1997 BMW started taking an interest in RR and they started supplying their joke utterly gutless V8s engines almost killing the Brand overnight - having ruined the company, in 1998 they let VAG (VW) make a massive financial blunder (at the time believed to be a stroke of genius) and VW bought the headache of the dying business with only the gutless BMW engines in the model range. In the midst of the carnage BMW popped up and mentioned the small print - where they did the dirty and got the RR brand without a headache, Leaving VW with just the Bentley brand, a tired factory and a model range of even uglier 45 year Shadow's now running 4Ltr moped engines
Owners of the previously torquey RR and Bentley 6.75ltr L410 V8s couldn't cope with the 4 ltr BMW engine'd models of the late 1990's. Owners couldn't understand why nothing happened when you put your foot on the throttle of these lawn mower cars from the Germans. The sales collapse quickly saw VW ditch the german engines and put a real one back in (which stayed till 2020 !!!). VW quickly fixed the power situation where they took the original V8 and put it back in the cars (a engine in development from 1952 until emissions killed it off the last real engine'd Bentley’s in 2020).
The idea one wanted to wait half an hour for the revs to pick up (and make uncouth noises) and then find gearbox wanted to downshift at least twice was an anathema to British drivers. They were used to pushing the peddle down 1/2 an inch and being in the next county without any additional noise...
There are a lot of factors that go into an engine and it matters what kind of car it's intended to go into. An RR is a boat that is about comfort and quiet driving, so the large displacement engines that don't want to rev freely are the perfect fit for a car like that. Ultimately these cars are a great application for an electric powertrain. It doesn't get any quieter than that in an RR. It's so quiet in fact that RR had to make the Spectre artificially louder, because the passengers felt unwell in the car. RR proved that cars can actually be too quiet. Our brain needs a certain level of noise to match with the sensation of speed and movement that our bodies experience.
Performance cars on the other hand use motorsport inspired engines that rev more freely. A large displacement engine while making lots of power down low is rather lazy to respond. That's fine for an RR, but not necessarily for a smaller, lighter and nimbler car with a quick throttle response. Can't have heavy parts rotate in the engine if you want a quick throttle response. So lighter flywheels, shorter strokes, forged light internals etc are used instead. Effortless power is not the same thing as responsive power.
So in that vein, yes I see where you are coming from. The Germans invented the sports sedan, so they are about lighter, nimbler and responsive cars. Britain invented the boat on wheels that wafts through the landscape with the throttle response of a tractor and the body roll of an ocean liner in the stormy sea.
it is by physics and it is the torque (force) that makes the car move. Power is a “man made” unit that tells how fast you can take that torque out from the engine and transmission, but the key is that it is the torque that makes the car move, not the power.
Small torque engines rev up with high gear ratios to move the car as the torque just isn’t there like in a big engine that moves easily without revving up.
A good example of torque vs power is a farming tractor. A 100 hp tractor engine is quite powerful and can pull very heavy tools behind it as the torque from the gear train is made to move heavy loads. You can put the highest powered car with 1000 hp in front if a plow that is dug in the ground a foot deep and it would not move anywhere just because that car will not provide enough torque (force) to the wheels to move the heavy load.
Force (torque) is a natural unit, power is a man made unit telling how fast someone can drive the high powered car but if power transmission is made poorly the car can have a poor acceleration, for example, but go fast at end if time allows for it.
This is why power from the engine is not the only factor in how fast the car is accelerating as the transmission needs to be done correctly to be able to get that torque (force) on the road surface to move the car.
Instead of me trying to explain it further, I'm just gonna leave Jason's video here. He did a great job explaining it.
https://youtu.be/u-MH4sf5xkY?si=9CRkbSBmaR5aVtG0
We are talking about the same thing but when you say “power moves the car” you are wrong. It is force that moves things, as said earlier, power tells how fast the force can do it. And with the cars that force is torque on the wheels against road surface.
And I always tell the guys parking the cars to please keep it under 200 mph.
This is basic physics and I leave it here.
