Is it possible to disconnect this without needing to drain the coolant?
Old Jan 4, 2026 | 09:24 PM
COUPCONNOISSEUR's Avatar
2010 CL550
This metal pipe is only on 4Matic models. It’s impossible to remove the fan shroud without removing it. I need a little more room to replace some parts. I can’t remember if I could do this without draining the radiator. Thank you
This metal pipe I have circled here is only on 4Matic models. It’s impossible to remove the fan shroud without removing it. I need a little more room to replace some parts. I can’t remember if I could do this without draining the radiator. Thank you
Old Jan 5, 2026 | 06:20 PM
EasyPhil's Avatar
2007 S550 4Matic 2013 S550 Base
Yes, you need to drain the radiator and remove that pipe to pull the fan shroud. I replaced an AC compressor this summer and had to drain the coolant on my 4Matic. I drained it to a container and added it back once the job was finished.
