Run Flats?
For the 20" standard suspension guys, don't regret keeping the RFT's if you do. There's no guarantee you'll feel much difference by the switch. If you have MBC like Chucky, the system may love the softer tires better.
My past experience with run-flats were that they were fairly noisy compared to comparable non-run flats in the same size.
Just spent 1900+ miles driving the S this weekend across many states with roads of varying surface quality. Based on my past experience I was thinking that the non run-flat wouldn't change ride quality a whole lot on some on the roads but on others would be more noticeable. The northern pot hole filled rough roads can be not only rough but also noisy. Sun baked asphalt southern roads, though not pot hole filled, can be rough and noisy.
Since the roads in our home area are comparatively in great condition I am thinking that I will just keep my run-flats and switch to normal tires when it comes time to change them in a year or two, but primarily for road noise reasons. But would like your opinion on the road noise change.
We have the run flats on the 20" wheels with airmatic suspension. The ride was noticeably "harder" when the temps were below 45-50 degrees. The ride was smoother once temps were above 60 and the tires were warmed up.
This is the same behavior I saw in run flats we had on a sports car in the past.
Chucky, have you noticed a road noise change since the switch? Just wondering if road noise is lessened. The road noise is more of an issue for us on our roads than the ride quality, but would always appreciate the better ride!
So to all those who endured this thread, lol, know that I am happy with everything and just needed time to adjust to the differences.
What you can always do is try something new each time you have to replace the set (lets hope not for 15k miles)
I think you are well served with your set. If your outside temps are above 60 degrees and you drive for awhile to warm them up, they will be as soft as they can be. If they are still too stiff, get another set when they are worn out.
I'm sure it was not malicious on their part, but false advertising is false advertising.
Thank you
I'm in SoCal and take delivery in June of a 2015 S550 w/ 20's. The roads here are fairly good, but based on the last few posts, it looks like I could force MB to change to non-run flats.
http://www.tirerack.com/accessories/...um=CCKV2&ID=38
