S-Class (W222) 2014-2020
How to turn off ECO start/stop
Old Mar 1, 2020 | 11:52 AM
  #76
Gazwould's Avatar
S204 C250 CDI Sport
Quite amazed really at the length and a commonly discussed issue with little in the way of a FREE answer .
Two free ones .
Disconnect the main battery connector to the negative terminal
( this goes stop 'HOLD' from working ) or
pull the auxiliary battery fuse .
Old Mar 2, 2020 | 04:23 AM
  #77
HAWKiS63's Avatar
S63 AMG Cabrio
Originally Posted by jnash
I don't believe the COMAND module has a seed-key restriction because I was in there a few weeks ago and enabled video-in-motion above 5 Km.
I'd have to go back in to see if there is a parameter to enable the Engineering Menu.
My dealer does need a special passcode to enable the Engineering Menu, they need input from MB HQ for this.
Old Mar 3, 2020 | 10:32 AM
  #78
nishboo's Avatar
W124, W126, W140, W220, W222, R129
It is possible to code the Eco Start/Stop, the parameter setting is in the Motor Engine module. The options (maybe car dependent), are something like enable, disable, and Last Setting. It requires coding using the Vediamo/Caesar program that can edit directly into MB modules. The problem getting into the ME module is that it requires a seed-key (password) to actually write changes. I wasn't able to do this myself without help from a friend who had the seed key generator. Anyway, mine now remembers my last setting, so if I turn it Off, it says Off until I enable it again - a much better option.
What would your friend charge to do this on a car via teamviewer?
Old Mar 4, 2020 | 04:39 AM
  #79
zetek's Avatar
S450 W222
https://mbworld.org/forums/s-class-w...ml#post7801199
as I wright - you can order this:
https://www.ebay.com/itm/MERCEDES-ca...EAAOSw2iJa-n9S
but be in touch before your order. You are to send your vin to this guy - codding for W222 restyle and before restyle is absolutelly different. Work perfect. I made official servise after that and it was no any question from dealer as for guarantee. I really forgot about that crasy system.
Old Mar 5, 2020 | 09:23 PM
  #80
benzliuqi's Avatar
C200
Mercedes-Benz ECO can choose the memory function, or it can be turned off for a long time.
Old Apr 30, 2020 | 02:54 PM
  #81
Ivan Vasilievic's Avatar
Gt63s 2019, GLC63s 2017
ECO Start Stop OFF ECO Start Stop OFF
Module
Old Apr 30, 2020 | 03:07 PM
  #82
nishboo's Avatar
Originally Posted by Ivan Vasilievic
Thats $249. Im looking for a way to do this via Star
Old Mar 11, 2021 | 06:40 PM
  #83
midcityeng's Avatar
PREMIUM SPONSOR
2013 SL550, 2016 GLE350, 2016 GLC300
For anyone annoyed with disabling the start / stop feature each time, you can pick up one of our OBD programmers that retains "last mode" for this feature, you can take a look at our vehicle coverages HERE. Pick one up today!
