2014 S550 cup holders
Can you fit two large drinks in the cup holders safely. Say from mcdonalds. I always had problems in older s classes with the drink cup holders being two small.
Not if the ashtray compartment is open. That must be open in order to use the cig lighter to charge your phone. Otherwise you can put a couple of cans in there and thats it.
I can fit two one litre soda bottles side by side but as Chucky300 said, the ashtray compartment must be closed. I charge my phone by plugging it into the USB port in the center console.
I haven't found a good place for change yet. The glove compartment is a black hole; there's a change holder there but its out of the way and can't be easily reached by the driver.
There may be an alternative place; its been too cold to sit comfortably and play.
to answer the cupholder question. You can fit two large mcdonalds soft drinks in them but the only thing I don't like is when you try to open the ash tray with the drinks in the cupholders, you will probably end up pushing the window defrost button
