UV/IR glass affecting cell phone reception
2015 S63, 2013 Range Rover
Has anyone noticed degraded cellular and Wi-Fi performance of your phone when inside the car? Just picked up a S63 and my Wi-Fi signal is a bar or two lower than when outside the car, and my cellular reception too. I didn't notice any problems like this with my 2010 S550, are they the same as far as the shielding on the glass?
Also I saw some owners say that the garage door transmitter is very weak, however I actually don't find this at all, which completely counters my cell phone issue.
Lastly, what do you find yourself doing as far as the Wi-Fi hotspot in the car? I have the rear entertainment package so connecting to the car Wi-Fi lets me use the iPhone as a remote for the screens which is infinitely better than the regular remote, but then I am stuck with the horrible 150Kbps throttled Verizon service instead of the LTE on my phone.
Does anyone have any good suggestions? Thanks!
Why not? If you really want good IR protection, you will loose radio signals inside the cabin.
The MS solution is to use the external cellphone antenna at the roof. Unfortunately it restricts options to phone models that have a cradle (one also needs the convenience phone option).
For us in Europe (ROW) bluetooth connectivity is still possible with a BT SAP adapter (unfortunately not all phones support BT SAP).
IR reflective windows are not standard for the W222 with the smallest engines (those that are available in Europe). Here MB suggests to tick the 386 phone option for those who want IR reflective windows.
Is there any solution other than to use a phone that supports Bluetooth SAP?
It's frustrating because the car has it's own separate data connection, if that was a real, working, fast connection it would be great since I can use that over Wi-Fi in the car, except it's completely useless.
What is the MS option you're talking about, would that work with an iPhone?
Thank you
Thank you
IR is light and cell phone signals use radio waves so is it possible to permit radio waves in without affecting the ability to repeal IR/UV?
For the existing situation would a 4G signal repeater/booster inside the car help?
http://en.wikipedia.org/wiki/Electromagnetic_radiation
A bandpass filter would be possible in theory but does not seem to be practical to build such windows.
4G can appear on any cellular frequency but you are right, a repeater could be used and repeaters can be built on specific frequencies only. I'm afraid FCC and other authorities would not make those legal?
The difference is only in the frequency (or wavelength). IR light has a lower frequency than visible light. If you want to build a low pass filter that blocks IR but passes visible light, you would block all electromagnetic radiation at IR frequencies and lower.
Electromagnetic radiation - Wikipedia, the free encyclopedia
My company recently hosted a gala at the DC Ritz Carlton and the ballroom is underground 2 levels down but I had a strong 4G signal throughout the event space and it really made things easy on the day of the event. I was told that they installed some type of a cellphone repeater as a part of their recent ballroom renovation. I searched around and you can buy these repeaters and they are pretty small. The key thing would be to have it professionally installed so it is completely concealed and find a place to mount the antenna (perhaps behind the grill where it is semi exposed?).
The manual says that the cut out for an EZ Pass is on the right side of the rearview mirror, on my S550 it was on the left (which makes more sense if you hold it up, harder to reach to right side of mirror), does anyone know for sure?
If I am sitting in the driver's seat the area where I have my EZ Pass is to the right of the rearview mirror (closer to the passenger side).
You can also verify the areas in the windshield available for this by setting your car in direct sunlight and looking from the outside into the car near the rearview mirror. You will see the area that allows the frequency through the windshield.
I also had a '08 S550 4Matic. It was the same as my '14 S550 4Matic.
