S-Class (W222) 2014-2020
Grinding Sound in Reverse
Old Jun 20, 2014 | 12:39 PM
TomS's Avatar
2014 S550, 2011 E350 Cabriolet, Asgard Mothership
I noticed something for the second time yesterday. It seems that after the car is washed, if I backup, I hear a what I would have to call a grinding sound. Both times I thought I had the brake on, but I checked that. I pulled forward then backed up again and it did not happen.
I have not confirmed it has anything to do with washing it (such as water on the wheel), but I was curious if anyone else has heard this.
Old Jun 20, 2014 | 01:57 PM
AppleFan1's Avatar
2025 EQS580
Tom, I don't think I have heard a grinding sound, but mine is more of a squeaking sound. I will be on the lookout and pay more attention when I back out of the garage. I will let you know.
Old Jun 20, 2014 | 02:35 PM
kurt benz's Avatar
ml 320 260 se c 200 kompressor
Mb is aware of problem and have released a updated front and rear pad set. Their sales manager's car had exactly the same problem and MB decided that the correct fix is replacement of all 4 brake rotors and pads.
Old Jun 20, 2014 | 04:20 PM
jrpisha's Avatar
2023 AMG SL55,2015 S550 4MATIC, 2023 BMW X5
My BMW used to do this too. After washing, the rotors on my 550i seemed to get covered with a light layer of rust/corrosion in the matter of 30 minutes or so. A short application of the brakes was all that was necessary to scrub off the offending rust & eliminate the grinding noise.
A minor inconvenience. Wonder if your issue is the same...
Old Jun 20, 2014 | 08:24 PM
DaveVY's Avatar
S 550
I noticed a sound like this once on our 2014 S550 and assumed it was the brake pads. One quick cycle of the brakes and no more sound.
