S-Class (W222) 2014-2020
Homelink Range Extended
Old Aug 4, 2014 | 11:48 PM
Cptdenny's Avatar
2009 SL600, 2015 Lexus RX450h, 2014 S550
I'm reposting this from an older forum sub-post.
How to increase the Homelink garage door opener range:
I solved it by lengthening the garage door operator antenna by a fractional wavelength. That is to say I doubled the length of the OEM opener antenna.
All you need to do is:
1. Get a piece of 18-22 gage (not important) wire exactly as long as the existing antenna (you will have to guess the length in some cases when the wire disappears into the housing).
2. Use a butt connector to join the stripped ends of the existing wire and the new one.
3. Let it hang down from the opener.
From my own personal experience the S550 now has a reasonable range. Prior my range was about 2' away from the door for it to open. After doing the above remedy minutes ago, I was able to open the garage door from across the street, a distance of about 100'. I didn't bother going out further at this time.
