iPhone 6 - problems with Personal Hotspot to S550 fixed with iOS 8.1.3 update?
I was easily able to use the Personal Hotspot function from iPhone 5S running iOS 8, but for some quirky reason, it just wouldn't work with iPhone 6 or iPhone 6+
I just upgraded to iOS 8.1.3 and I will report here if the problem has been fixed by this update as of Jan 27, 2015.
If anyone else knows what I am talking about, I'd appreciate your input.
I just got my car in January, and have not been able to get my iPhone to provide internet (wifi) to the S550 from iPhone 6/6+
It may be a Bluetooth issue actually, not that surprising. Still working on it.
Probably most of us realize that it is not so useful to have the S550 share access to the internet through it's own wifi hotspot when the source of the internet connection is some Mercedes branded built in pay service with 3G speed limits. Maybe it has a wide range of service across the globe or something advantageous that I am not seeing, but I think the speeds would make it painful to use.
Most of us realize that it is trivial to share internet from any iPhone with Personal Hotspot directly without the S550 being involved.
BUT - I want to share the iPhone's LTE data internet connection over Personal Hotspot wifi with the S550 so I can try out the built-in apps, and other "built-in" browser things on my fancy dashboard.
I tried it this evening, and no luck.
If you have a 5S it's no problem to use personal hotspot as your wifi internet source so that you can access the "Mercedes Apps" and "Mercedes Mobile Website" - but I have not been able to get it to work with either iPhone 6 or 6+
I have taken it to the dealer and one of the salesmen who thought he could help me do it in 2 minutes was stumped for an hour before giving up as well.
I think the S550 might possibly need a firmware update that addresses the issue.
There is something non-standard about the way it tries to link up to the personal hotspot on an iPhone 6.
I'd like to know if ANYONE has used personal hotspot on a 2015 S550 successfully with an iPhone 6 or 6+
How about anyone else at least doing it with a 5S? I can do it with my old 5S too, but would like to get someone else to help me look into it.
If anyone knows how to find out if there are any service bulletins about this issue, that might also help.
I'll keep looking into it and see if I can find the solution - I doubt that it's just me, but that is a possibility. But more likely it's a problem that nobody else or few people have noticed yet.
I tried with iPhone 5s and another android phone but was not able to access the "Mercedes Apps" and "Mercedes Mobile Website" using the wi-fi hot spot of my phone.
How did you do it using your iPhone 5s? Appreciate sharing with us your experienceon on this.
Thanks.
Thanks.
I'll be doing some testing with a friend on the weekend.
My friend has an iPhone 6+ also.
I have an iPhone 5S, an iPhone 6, and and iPhone 6+
When I swap my sim card to the 5S - I can get Personal Hotspot working on 2015 S550.
If I try the same sim card on my regular iPhone 6+ it doesn't work
If I try the same sim card on my alternate iPhone 6 it also doesn't work.
Now I will try my friends iPhone 6+
If it works on his, I will try some other combinations to find the culprit:
I will try with my friends iPhone 6+ with my sim card
I will try with my iPhone 6/6+ with my friends sim card
These results will be interesting for the debug I believe - so I am interested to see the results.
PS - While we do some testing I will make a quick video of the successful "Personal Hotspot" tethering procedures from the iPhone 5S and post a link to it here. I could write the procedure, but am hoping I can find a quicker and better way to illustrate it for you and all the others who may be interested.
Thanks.
Sorry I didn't make a video but I'll explain briefly for now:
On your iPhone, turn on Personal Hotspot in "Settings - Cellular - Personal Hotspot" - you have to give it a password to turn it on, but don't worry, with Bluetooth tethering, your vehicle will not need to use the password, it will just use the bluetooth tethering method of using your iPhone's personal hotspot.
Have you already paired your phone to the car previously? If so, then all you need to do now is navigate to Phone/Internet, and turn the knob to "Internet" and select that. Then select one of the internet choices (mercedes apps, or merc mobile website will be fine). You should see that the S550 is now showing on the screen that it is "connecting" to your phone. On your phone you should see the blue bar showing that you have a live connection on the phone's "personal hotspot" - this is KEY. If you see that there is a personal hotspot connection, you know that it's your S550, and probably all is well.
If you have never paired your iPhone to the car, do that. Your phone connects to the S550 over Bluetooth, so make sure this is turned on in Settings - Bluetooth on your iPhone. "Connect Devices" from comand - search for phones and select your phone. It will negotiate a connection with your iPhone and pop up a dialog box. You'll also get one on the Comand. OK to all. You may wish to view info on the MB Bluetooth connection within the "Settings-Bluetooth" screen on the iPhone - tap the "i" with the circle around it for "info" on the connection. It might be good to turn the switches on for "Show Notifications" (good for texting functionality) and "Sync Contacts" - for phone book stuff (not related to what we are doing, but whatever).
Try that and you should be able to get internet unless your phone is messed up like mine.
My big debug results:
I just got together with my friend who has an iPhone 6+
Here are the results
His iPhone 6+ connected no problem.
His iPhone 6+ connected no problem using my sim card in his phone
My iPhone 6+ could not connect (using my sim of course)
My iPhone 6+ could not connect even when I swapped in his sim card.
This tells me that my phone hardware or something about my phone hardware and sofware is more likely to be the culprit than anything to do with my sim card.
I turned on Personal Hotspot, and my friend could connect to my personal hotspot easily, but the car could never connect to my hotspot.
If I put my sim card in my old iPhone 5S - Personal hotspot to the S55 works with no problems
I believe my S550 has a "memory" of my iPhone's Bluetooth address somewhere in memory in a bad place that is causing it to ignore my iPhone - discriminating against it on the basis of some bluetooth address memory. This is the latest theory. I have seen this before, and usually the fix would be to reboot the iPhone. (I have since thought about disconnecting the battery to the S550, but I am a bit leary of doing that haha - I think I'll get the mechanic to factory reset the comand system and ask about a hard reset of the vehicle if it's easy to try.)
I have also tried resetting network settings, forgetting the bluetooth connection, rebooting the phone - all combinations. This can also shake out the voodoo, but no good result trying those things.
I have an iPhone 6 that I don't use much - The next test will be to factory reset my iPhone 6. I think this has a good chance of fixing the problem. If it doesn't, then I will be looking to do a hard reset of the S550
SOLUTION!
How to Fix iPhone 6 Plus Bluetooth Issues
The iPhone 6 Plus does not connect to in-car entertainment and hands free systems well on iOS 8 and iOS 8.0.2. If you experience these problems the first step is to update to iOS 8.1, which fixes many iPhone 6 Plus Bluetooth problems.
If you still can’t connect to specific Bluetooth devices or accessories you may need to reset all settings. You will need to re-setup your settings, but you don’t lose data or apps. Go to Settings > General > Reset > Reset All Settings.
So I did this on my iPhone 6 and got it working instantly.
I expect the same result with the iPhone 6+
I really didn't want to reset all settings, but it was the next step before doing a full factory reset on the phone.
IN SUMMARY
I had Bluetooth problems that were resolved on my iPhone by resetting all settings. The end result is that I am finally able to share internet with the S550 using Personal Hotspot (Bluetooth tethering)
Then I visited Bluetooth and saw some residual Bluetooth connections and manually deleted these - I thought reset all settings would have gotten rid of all those, but I had to manually clear out about 5 mystery bluetooth devices (only hexadecimal names were shown, no friendly names).
Turned on Personal Hotspot and then paired up to the phone from the S550, then visited phone - internet ( on S550 "comand"), and got the car on the internet.
That was fun!
The Car runs it's apps through the wireless bluetooth connection - Bluetooth Tethering to the iPhone. The Car is connected to the iPhone through the iPhone's "Personal Hotspot" feature, but not through wifi, but rather through Bluetooth.
The iPhone Personal hotspot feature is typically and normally thought of as a way to share the phone's cellular internet connection to other "computers" over wifi. That is the typical "use case" - but Bluetooth tethering is another way Personal Hotspot can be accessed, and that is the way the S550 Comand system (or whatever it's called) connects to the iPhone to get internet.
My iPhone sometimes gets an "LTE" connection (depending on location of the iPhone), and other times it is "3G". LTE is the faster one and is also referred to as "4G" I believe. I can tell you that the apps load up stuff pretty fast - maybe even "snappy". I am also located in Canada and that may make a difference - not sure. Perhaps someone else can comment about the bandwidth limitations of the Bluetooth connection. I don't even know if it is Bluetooth 2.0 or Bluetooth 4 "smart". It matters. I think Bluetooth 2.0 might have more bandwidth. Bluetooth smart is more about low energy consumption for the "internet of things"
Too much jargon, and too many exceptions and too many misconceptions make what should be a simple thing to the end user seem convoluted. I think they really could kill the bugs if they just quadrupled their software and firmware engineering and made it a goal. When I say "They" I mean Merc and Apple - both of them. The car itself is as perfect a car as I have ever owned, but the entire computer side of things (comand system etc) is not good enough - at least not yet.
All it takes is someone to care and pursue the bugs. Maybe I should petition them to be head boogieman of the "comand system development".
Do the guys designing the software and human interface drive S550's daily? If they did, they would make it kick ***, right?
To answer about setting up "your wifi hotspot" - this can be done instantly and easily from any iPhone - jailbreaking is not required or desired. The problem here is bringing the S550 into the mix. For whatever reason, you cannot connect your S550 to a wifi network directly. For instance, I have my S550 in my garage right now. You'd think I would be able to have the S550 connect to my home wifi network. You cannot.
iPhone gets internet from cellular data network.
iPhone shares internet typically through wifi, but it can also do it through USB and/or Bluetooth.
It would be nice if the S550 had 2 WiFi's, but it doesn't apparently.
S550 can get internet through it's own built in "thing" - not sure what it has - I have read here that it is some 3G cell thing, and it's slow and limited or something - no idea really - just telling you what I have heard
S550 can get internet from an iPhone through Bluetooth Tethering.
Bluetooth Tethering to iPhone means the S550 uses Bluetooth to connect to the iPhone for it's internet connection.
Perhaps one cool thing is that the S550 can get internet from the iPhone using Bluetooth tethering (via the iPhone Personal Hotspot functionality), and then the S550 (can, or) could and should be able to then share it's own internet connection through it's own Wifi. It's all funnelling through the iPhone so it would be slow, but whatever, I think this would work, and in some places (countries) this would be better than nothing. But having said that, if you have an iPhone, you can also provide wifi directly and do not need to patch it through the S550. It makes me wonder what the heck Merc was thinking when they added a wifi network to the car. Why would I want to connect to the internet through the car wifi? I would only do this if there were a speed advantage, but there is actually a big disadvantage to do this if you use the 3G cell connection that is available directly through the car, and if I use my iPhone, why bother going through the car first? Just go directly.
It's similar to the strange logic of having these LCD screens in the back seat of the car - why bother. I'm glad I don't have them - any passenger can use an iPad and have the same or better functionality. I guess it's the same in first class on an airplane. They give you these movies and stuff, but you have to watch it on their dim TFT display - you do better by using your laptop or iPad. It's funny how we have layers of redundant tech going on here, but still no obvious solutions. It's like the engineers are not thinking about the end user.
Sorry if my posts are long and full of redundancies - I posted like this to eliminate ambiguities that frustrate the forum reader (like me). I think 3 letter acronyms and jargon make it hard for readers to learn. For example, I incorrectly assumed that "Personal Hotspot" was strictly "wifi". It is not. And I should know better cuz I am a bit of a computer nerd, but I assumed that's what it was, and it is not.
No worries man, it seems simple as hell what you want to do and you are doing a more complicated setup that is not working either. I suggest you contact mbusa and apple to see if they have some info about it. The car is new and advanced im sure it's possible with firmware updates you will get it working properly. I think the only thing hindering the vehicle is that is actually has the 3g setup so they are pushing that instead of a practical wifi sharing setup. Good luck
I resolved my issue connecting my S550 to my iPhone 6 personal hotspot.
Now that I have resolved it, I don't think the problem will come back again for me but it would not surprise me if others out there get into the same trouble that I had.
My Canadian S550 connects to my iPhone personal hotspot automatically now. It connects to the iPhone personal hotspot using "bluetooth tethering".
Here are my next activities I will do:
1. Someone wanted to know if the S550 can now share out the internet on it's own wifi connection after having already connected to the iPhone's personal hotspot. I'll check that. The benefits of doing this are probably limited, but that is not relevant - he just wants to know if I can do that. I'll check.
2. I will use the S550 web browser to navigate to "speedtest.net" and see if I can run a bandwidth test while I am connected to the iPhone, and the iPhone is showing LTE connection. I might also repeat it while the iPhone shows a 3G connection to see if it makes any difference. The goal of this test would be to try and compare bandwidth differences if any are present, and it might reveal if there are bottlenecks on the "bluetooth tethering" side of things. I think the Bluetooth may in fact be a bigger bottleneck that 3G/LTE. I think this test has a chance to show something real, although it would not be taking into account the cellphone internet quality. It might take several test trials in different locations near different cell towers to really know, and I probably am not that interested to do all that. Simple enough though to run a speedtest and look at the results. People talk a lot about 3G and LTE 4G - I'd like to see what real world results are.
I have no idea about Canadian vs USA S550 configurations - I know there are some quirks. I wish I had a software tool to get into the Comand system and remove all limits. But that is another topic.
SOLUTION!
IN SUMMARY
That was fun!
i will try your method by resentting my phone and hopefully this will work.
