S-Class (W222) 2014-2020
Oil Change
Old 03-15-2016, 04:46 PM
Keadog's Avatar
Porsche Boxster
Thanks - I have seen them mentioned on Rennlist.
Old 01-08-2017, 04:59 PM
2014CL600's Avatar
Cars
Is there a drain plug on the 4.7 Bi-Turbo engine or not?
Old 01-10-2017, 01:32 AM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
Originally Posted by 2014CL600
I see people ask a question and other just interject opinions and such. I am changing my friends 2011 4.7 Litre Bi Turbo CL 550. I have removed the under pans but can not see a drain plug. Is there one or not? A simple yes or no please where is it? Thank you.
BTW, the link someone posted was for the OLD engine 5.0 engine. Not the 4.7 Bi-Turbo 4 matic. They are drastically different.
Does this car require a extraction method or can it be drained like any other normal engine. My 2014 CL 600 still can be drain normally.
Yes, you can drain it normally. You just need to remove the plastic covers underneath first to get to the drain plug.
P.S. I posted the Part numbers and Excellent pricing for Oil and Filters...
https://mbworld.org/forums/new-s-cla...s-pricing.html
I purchased one of these extractors from amazon a while back. Works great...
https://www.amazon.com/Dynamo-18-Gal...=oil+extractor
Was only $225- when I purchased it. I don't use the top drain pan. Its great for just about anything. On other cars / trucks, when you siphon transmission fluid, you can see how much you took out and put back the same amount.
Question, don't most manufactures quote XXX miles or once a year, which ever comes first for Oil Changes?
Old 10-13-2020, 09:24 AM
warobert's Avatar
ml320
There is a Yu Tube video on how to change the oil on W222
Quick Reply: Oil Change
