S-Class (W222) 2014-2020
S Class Factory Rear Entertainment Question
Old Apr 11, 2016 | 04:34 PM
Chucky300's Avatar
2014 S550
Say you want to stream a video from your phone to your rear tv screens.
How does one go about doing this?
Any thoughts?
Old Apr 11, 2016 | 06:08 PM
TestnDoc's Avatar
S550
Not with OEM.
Old Apr 11, 2016 | 06:09 PM
Chucky300's Avatar
2014 S550
Originally Posted by TestnDoc
Not with OEM.
Thank you.
Suggestions on aftermarket hook up?
Old Apr 28, 2016 | 09:32 AM
puhngtAMG0444's Avatar
Mercedes Benz E350, Toyota Highlander Limited, Saab 9-5, BMW 5 Series, W222 S Class, W205 C Class,
I don't think you can. I have an S class but not with the rear entertainment option, there might be some aftermarket options but I personally would not modify the command system in car.
2014 S550 4matic W222
2014 C250 W204
2015 C300 W205
2014 Ml250 BlueTec W166
2008 E350 4matic W211 (Favorite)
2013 Toyota Highlander Limited
2000 Saab 9-5
2008 BMW 525i
Old Apr 28, 2016 | 07:03 PM
Wolfman's Avatar
Super Moderator
The S-Class is prehistoric when it comes to AV connectivity. No HD, no streaming, nothing digital on the video side, only analog.
The BMW 7 series can stream Netflix and has HDMI inputs which enables a whole host of video input options.
On the MB, it's best not to have any the rear entertainment option but to simply get the MB iPad seat mounts, a couple of iPads, an Apple TV (or similar) and then decide if audio goes into the Burmeister or some Bluetooth headsets.
Those cost a fraction of the rear entertainment option and delivers 10 times the (entertainment) value...
Old May 1, 2016 | 03:05 PM
rlajos's Avatar
w222
Raspberry PI as Airplay receiver
I would build a Raspberry Pi 3 with KODI rig. It has also a composit video output (output format can be customised to almost any video standard), so it can be a solution. Nevertheless agree, this DIY stuff is not for MB class...
Old May 12, 2016 | 06:32 AM
c.cal's Avatar
S 350 L
I just bought a Google Chromecast. It's powered through a 5v USB, so it can be stored in the armrest. The only problem is that it's only HDMI so I also had to buy an external HDMI2AV converter (also powered via USB 5V). They should both be stored in the armrest.
With Chromecast I can also stream from Netflix, but I don't know if the slow wifi module of the car allows to watch the contents...
Unfortunately my car now is at the dealer's so I can't try the whole system. Other news when I'll have the car in my hands.
Carlo
