H or V rated tires?
This is a good read. With a S class I would be more worried about load rating than the speed rating. Especially when the difference between the two you are looking at is 19ish MPH
Both H and V (and a whole bunch of other letters) designate higher speeds than you subject your tires to.
And one or two quick bursts of speed up to 100 MPH is vastly different than cruising at 100 MPH due to the heat load in the tire.
So, concentrate on the load rating, traction ratings, and wear ratings.
{And admit that some of us hate run craps.}
Thought about dropping down to S rated to get a more comfortable and quieter ride. The current Michellins are very noisy.
