S-Class (W222) 2014-2020
W222 Front Pads & Rotor Replacement
Old 10-30-2016 | 11:18 PM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
Is the W221 process in the video the same on the W222?
Old 12-09-2016 | 07:41 PM
Nice Ride's Avatar
Anyone? I know that most people just go to the dealer for everything. I personally like to some basic stuff on my own.
I always do Oil Changes, Brake Flush, Radiator flush etc. On these cars what you can do is very limited. So I'm left with Oil Changes, Brakes, Rotors, Brake Flush.
Any info will be appreciated. There must be some shady tree mechanics that enjoy doing some of the basic stuff...
Old 12-09-2016 | 07:51 PM
ItalianJoe1's Avatar
2003 CL 600
Yep, it's just basic brakes. 222 is almost identical to the 221 stuff, just bigger 2-piece rotors. Don't drop them or lift them by the center hub, but it's nothing special. Replace the caliper bolts as they are one-time use.
Nice Ride (12-09-2016)
Old 12-09-2016 | 09:39 PM
Nice Ride's Avatar
Thanks for the response!
Would you happen to know if you need to enter maintenance mode through the DIC so the rear calipers retract to do the Pads and Rotors? I remember reading this somewhere...
Also, I usually do a brake flush every 2 to 3 years on all my vehicles. I use the MOTIVE kit, works great! The only problem I found is that for some reason there is a screen on the MC so you cannot suction out the reservoir first before the flush. I don't see any way to remove the screen..... I usually suction out the old fluid first then fill with fresh followed by the Bleeding procedure. Is this only on the 222 or is it standard on MB. This is by first MB.
Thanks again!
Old 12-09-2016 | 09:43 PM
Nice Ride's Avatar
On the 2014 222 S-Class Sport Package, I think they have 1 piece rotors. Isn't the 2 Piece on the S63?
Old 12-09-2016 | 10:46 PM
2003 CL 600
Thanks again!
Yeah the rears have to be released before pad replacement, through the maintenance menu or via Xentry.
The little screen cup should just lift out. But there's not that much room to put a hose down into the bottom of the bottle to suck fluid out.
Old 12-09-2016 | 10:47 PM
2003 CL 600
I've done them on S550s, not just AMG cars.
http://www.ebay.com/p/Mercedes-W222-...-72/1030199499
It doesn't look like a dramatic 2-piece, but it still has a floating center. Gotta treat it with a little more respect than solid rotors, that's all.
Nice Ride (12-10-2016)
Old 12-10-2016 | 11:34 PM
Nice Ride's Avatar
Yup, strange that it is blocked by more plastic. I bleed most of it out, then I do a fill and flush. Just have to be careful not to let it get low and air in the system. I know you can use the Xentry to activate the ABS to flush properly... I'm not too worried for the small amount, eventually it will be mixed with the line fluid and the MC res.
Is the Xentry the only way to get the ABS to cycle for an automated flush?
Old 12-10-2016 | 11:35 PM
Nice Ride's Avatar
They have directional vain's? Never really checked... Also, anyone use pads that have less dust but are recommended by MB if such a set exists...
Old 12-11-2016 | 12:20 AM
Nice Ride's Avatar
Found them for $143-
http://www.mbdirectparts.com/mercede...art_name=rotor
Old 12-11-2016 | 02:00 AM
2003 CL 600
I don't think they are directional, the part # is the same for both sides.
MB doesn't have an optional pad here in the US, in another market they may use different compounds. But you could always try an aftermarket pad and see what results you get.
Nice Ride (12-11-2016)
Old 02-02-2017 | 12:32 PM
apsdop's Avatar
S 550 - 2015
In my entire life I have never replaced brakes and rotors on a car that has 25,000 miles. Supposedly I need to replace them on this car.
When I ask why he cannot just replace brakes he says you cannot do that on a Mercedes or you will get vibrations when braking and of course -- CANNOT resurface the rotors
Also claims that on an S Class 25,000 miles is usually what you get out of brakes and rotors.
This sounds ridiculous. First (and last time) I ever owned a mercedes, but never had this in all my other luxury cars.
Is this right??? $1900 for brakes and rotors ?!?!?
Old 02-02-2017 | 03:38 PM
jfz219's Avatar
2019 ES300h
Dealership service is less expensive in flyover country. My S550 required pads only at 55,000miles. Total cost under $500 for all four brakes. As long as the pads don't score or warp the rotors, the rotors usually stay in spec.
Old 02-02-2017 | 05:36 PM
2003 CL 600
We see 217/222 cars needing brakes as soon as 10K miles, depends on driver and conditions. With the traffic here it's not unusual at all. Yes the rotors are horrendously expensive, consider buying online instead of paying full dealer markup.
You can almost always put pads on the old rotors at least once, with no real adverse effect. If you have slightly warped rotors though, you will notice it more with the new pads, as they wear in and build up more pad material on the high spots that were already there.
Old 02-07-2017 | 03:47 PM
apsdop's Avatar
S 550 - 2015
I think I'm sticking to brakes only with no rotors. Hopefully the dealer doesn't "fix it" so that perform poorly on purpose. Realistically only needs to last another 20K miles or so and then I can give this nightmare of a car back
Or better yet -- is there really a downside of getting brakes/rotors at a Midas?
Old 02-07-2017 | 05:12 PM
Socalsteve's Avatar
2015 MBZ S 550
Nightmare of a car because it needs pads and rotors? All German cars are the same. The recommendation is ALWAYS to replace rotors with pads. ALWAYS. Every German car manufacturer.
Call any BMW, Porsche, Audi or VW dealer. They will all tell you the exact same thing. 25k miles isn't bad. Try owning a Cayenne or Touraeg. You may see 15k miles before the pads AND rotors need to be replaced.
High end German cars are high end for a reason. The tolerances are very narrow. And their performance is stupendous. These things go together.
You are driving a 449 hp vehicle that weighs almost 2.5 tons. My suggestion to you is to replace pads and rotors. Take it to an independent shop if you think the dealership prices are too high, but at a minimum...follow the recommended specs.
Your life could depend on it.
Good luck! Maybe next time you'll buy American or Japanese. German cars are not for you.
Nice Ride (10-09-2017)
Old 02-07-2017 | 05:26 PM
apsdop's Avatar
S 550 - 2015
Yes a nightmare of a car because the brakes started screeching 9K miles in and I've had to live with that sound for the last 8 months; followed by non-stop maintenance requirements that are not inexpensive.
But you are absolutely correct - I'm going back to my Japanese Lexus LS. At least there I know when I get my car I'm not stuck with an additional $5K in maintenance over 24-30 months.
My LS's were powerful cars that weighed a bunch too. Yet somehow they never required rotors even at a 50K mile mark. Moreover, when I needed to change brakes they were reasonably priced.
I understand that many folks here think it is some sort of honor/privilege to drive a Mercedes -- the dealer/service people sure think that way too -- but it is a car. And only marginally nicer than my LS was. The bottom line here is that when you make a deal on a lease you need to budget 15-20% more for maintenance items that don't exist on an LS or a Jaguar or even a BMW (since they pay for your brakes)
Old 02-07-2017 | 06:03 PM
Socalsteve's Avatar
2015 MBZ S 550
I'd love to know how you spent $5k in maintenance over the last 30 months? How many miles have you driven in that time? What type of driving was it ( freeway, city or stop and go )? Where did you have your vehicle serviced and did you buy the pre-paid maintenance package? Mine was $1,700.00 for 36 months ( 3 servicing ).
Even the 3 911's I owned were nowhere near that amount in maintenance costs.
I'll never dispute if you think an LS is as nice as an S Class. We all have certain levels and standards that we are comfortable with. If you feel a Japanese car is only marginally less than a German car, that is your right.
Old 02-07-2017 | 06:13 PM
apsdop's Avatar
S 550 - 2015
I'm 16 months in and 25K miles. I had prepaid for the 2 maintenances (which I think was $1000). Have had to do 2 alignments ($400). Brakes/Rotors are $1900. That's $3300 and I still have 14 months to go. Now I won't actually end up spending $5K because I'm not going to fix the brakes there or do a non-prepaid maintenance, but if you were a yes-man and did what they told you, I'd easily get there.
Mind you, I was told I NEEDED to replace the brakes and rotors when the car started screeching at 9K miles.
P.S. The Lexus LS was just as quiet as this S Class, S Class is a bit smoother though and has more toys/features. Side note - I have an E Class as loaner and my wife's Volvo drives better than this E Class.
Old 02-07-2017 | 06:46 PM
2003 CL 600
At 9k miles the brakes and rotors were still under warranty....
As above, if the noise is bothering you, rotors may be necessary. I've never seen a properly done brake job make noise, but it's possible.
There is no way for the dealer to "fix it to not perform properly", whatever that means. If you need brakes, you change them. It's a wear item. There are cars out there that are driven mildly and the brakes last the term of the lease. What sets these big german cars apart, is you can throw them around like a much smaller/lighter car and it will still perform. The price you pay is that you go through consumables at an alarming rate and they aren't cheap.
Buy new MB rotors online and have an independent shop install them, if you are trying to save. Dealer markup is insane, but that's no reason to use sub-par components on a $100k car.
Old 02-07-2017 | 09:05 PM
Nice Ride's Avatar
Early on I found the OEM parts, not that expensive if you ask me.
Old 02-08-2017 | 07:30 PM
1guitar's Avatar
E300-4matic
Caliper Bolts
I think you might want to double check your information on the "one time" usage of the caliper bolts. I have the MB factory repair instructions and it doesn't say anything to the affect that the caliper bolts are one-time use or throw away bolts. They do mention that the proper torque is 250 Ft. Lbs., wish I had an air drill instead of a breaker bar. Good luck.
Old 02-08-2017 | 08:02 PM
2003 CL 600
If it doesn't say specifically, you still need to reference the WIS document on fasteners. The factory caliper bolts have encapsulated sealant on them, and any bolt like that is one-time use as the sealant activates when installed the first time only, and is no good to re-use.
1guitar (02-09-2017)
Old 11-24-2017 | 11:35 PM
@rt's Avatar
@rt
W222 S550 4matic
Hi,
I tried to search through google as well as this forum. How to properly access that maintenance mode for rear calipers to retract? And it is only for rear calipers that must be done through this maintenance mode? front calipers you can push in manually, correct? All i found is this pdf from other thread. But I think this is for reseting the service light...
File Type: pdf
Old 11-25-2017 | 08:53 AM
2003 CL 600
Originally Posted by @rt
Hi,
Once you're in that menu with the service reset, there's an option to release the rear calipers as well. It is only for the rear, front are normal.
