After market comfort box
At the rear, there is a round sort of plug, which just slips into a hole in the steel frame behind the seats. At the front, there is simply another sort of protrusion, with a knob to turn it. Insert into the hole in the top trunk metal frame and twist the knob to secure. Goes in and out in less than 20 seconds. Good luck.
next question, can you install the trunk hooks even if you have the boot box/comfort box? I doubt you could pull them down with the rails in place, but maybe have them, and then for,non-comfort box days have those package hooks available...
thanks for any thoughts.
possibly in England). Went right in, no issues. I noted 2 things:
1) fully extended, or I think at it’s limit, it’s able to sit on the trunk floor, so that was a nice surprise to me. I think that would let it hold more than it’s rated 20 pounds (limited by floor strength, and lateral forces on the sides versus up and down pressure), and
2) my car clearly did not have the comfort box option from the factory.
hope this helps anyone interested!
