Does anyone have the issue of a rattling passenger seat backrest on not-so-smooth roads? I have this only when the seat is non-occupied. If there is someone sitting, then it is quiet as a mouse. My F10 had the same problem too, so I am starting to think that it is my luck...
Anyone with a similar issue? And if so, any remedies? It is a 2018 S560 by the way...
I think I have the same thing - haven't had anyone sit in the seat to isolate the issue, but I definitely have been complaining about what some seat vibration sound when on rutted roadsOriginally Posted by salamigs
Does anyone have the issue of a rattling passenger seat backrest on not-so-smooth roads? I have this only when the seat is non-occupied. If there is someone sitting, then it is quiet as a mouse. My F10 had the same problem too, so I am starting to think that it is my luck...Anyone with a similar issue? And if so, any remedies? It is a 2018 S560 by the way...
I noticed a similar rattling today and couldn't quite determine where it was located. This may narrow it down for me and I'll ck it tomorrow.
Quote:
Well paint me stupid and call me Lucy, but my problem was simply the mount on my radar detector. The windshield must be slightly more/less canted and I simply re-mounted as in the old car. Drove me nuts finding it, but I did and MINE is not a backrest or other rattle. Back to being quiet as a church.Originally Posted by flint350
MichaelinChicag
close
- Join DateApr 2018
- LocationChicago
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive2019 S560 Sedan
Liked:7 Times in 7 Posts
I have the same issue with my 2017 S550. Were you able to fix yours?Originally Posted by salamigs
I discovered that once I put the rear right in chauffeur mode and back, the rattle disappears for some time (2-3 days for me, I am sure it is also a function of the roads I drive on). After that, rinse and repeat....
I had the same problem with my 2015 S550. Dealer replaced the passenger headrest under warranty. No more rattles. I suspect that it is caused by someone not using the seat adjustment buttons on the door to move the headrest up and down.
brass / bronze / nylon busing I.D. 12mm O.D. 15mm length 5.5mmOriginally Posted by salamigs
ExploreMember
Quote:
Hi SilverioLuna,Originally Posted by SilverioLuna
please could you explain the brass / bronze / nylon bushing --- is this a solution and for which part ? Thank you
