How do you set "Home" in a 2014 S600?
Is there an easy way to set "home" in the car? In my 2004 Lexus LS it has a button you can set as "home" as well as a voice command "go home". In the MB S class all I can figure out is to put it in a previous destination and go from that list. Is there a way to permanently select "home" so you can get to it quickly if you're lost either through the menu or voice commands?
I went through the manual and can see about connecting to your phone contacts, but can't seem to figure out a way to set "home" in this car. There was a detour the other night and I got lost and could have really used it.
There's nothing in the video about using voice commands to get home. When I double checked I did save my home address under "my address". What I figured out is if you say "my address" it will bring it up under "contacts". From there you can say the line number to go there. Not sure why they don't call it "home", but this should work if I can remember it.
You have to set your address first. Look at the post by konigstiger with instructions about how to do it.
You can download the manual from mercedes benz.
https://www.mbusa.com/mercedes/servi...&class=S-Class
Page 75-77 on the manual, 77-79 on the pdf:
https://www.mbusa.com/vcm/MB/Digital...4-S-COMAND.pdf
