S-Class (W222) 2014-2020
Oil Dip Stick Location for 2015
Old Apr 27, 2019 | 02:09 PM
Prochambers's Avatar
2015 S550, 1987 420 SEL
Greetings all,
I need to check the oil level on my car and according to the operator's manual, the Oil Dip Stick should be in front of the Oil filler cap. I've looked and I do not see anything there unless it's under the black plastic cover. I did notice a dip stick towards the right rear of the engine (drivers side) that I highlighted in RED. Can someone help me out on this one. Appreciate it! Thanks.
Old Apr 27, 2019 | 02:30 PM
garymac's Avatar
2009 SL550, 2016 E350, 2019 AMG GT rdstr
I have a 2015 S550 and that is the dip stick location on my car.
Old Apr 27, 2019 | 08:59 PM
seamus2154's Avatar
2016 S550 sport, 2018 GLC300, M3, Zo7, 2021 Sierra Denali
I have a 2016 and it is a red dipstick right in front of the plastic cover front of the oil cap as you described.
Old Apr 27, 2019 | 09:22 PM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
That's it. Make sure when you test oil level, you remove and re-insert and test a 2nd time. For some reason on this engine, a vacuum will occur causing the oil to be sucked out of the dipstick causing you to believe the car is very low on oil.
Old Apr 29, 2019 | 09:11 AM
Yes indeed! I have to get used to this type of dip stick. Way, way different from my 1987 420 SEL. Thanks.
Old Apr 29, 2019 | 11:06 PM
Nice Ride's Avatar
Exclamation Careful with Snorkle(s)
Originally Posted by Prochambers
Greetings all,
NOTE: Be Extra Careful if you remove Snorkel(s) if doing your own Air Filter Change. They Break / Split on the soft tube extremely easy..... And cost over $75- to replace each...
Old Jul 15, 2019 | 09:17 PM
steinjr's Avatar
Veteran: Army
2015 S550 4MATIC
New to S Class. All my other Mercs alerted on the dash if oil got low. Will a 2015 S550 do the same?
