S-Class (W222) 2014-2020
S550 Steering Wheel
Old 05-29-2020, 01:36 PM
madkow70's Avatar
'20 GLS580, '18 S560
Here it is.
Old 07-25-2020, 07:01 PM
Jermaine Sledge's Avatar
S550
Will this support 2014w222
Originally Posted by madkow70
Here it is.
Will this support w222 2014
Old 07-26-2020, 10:31 AM
trustz's Avatar
2010 W204, 2014 W212, 2015 W222, 07 SAAB 9-3, 2016 AMG GTS
You need a airbag and a decoder in order to put in a W222 2014:
https://www.ebay.com/itm/Mercedes-Be...72.m2749.l2649
My 2014 W222 with 2018 custom AMG steering wheel:
Old 07-26-2020, 10:44 AM
Tom in Austin's Avatar
2016 S550, 2015 Honda Civic Hybrid
Does the adapter convert cruise control from the column stalk to the button on the wheel?
Old 07-26-2020, 10:51 AM
trustz's Avatar
No, you will need use the cruise control stick on your steering column.
Old 07-26-2020, 11:08 AM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
Did your car come with carbon fiber trim or is that aftermarket. Would love to swap out my woodgrain for something with this look.
Old 07-26-2020, 12:56 PM
  #32
trustz's Avatar
I got the carbon fiber trim from here:
https://www.ebay.com/itm/Mercedes-S6...EAAOSwboFec9FA
Old 07-26-2020, 05:43 PM
  #33
superpop's Avatar
Holy Smokes, 4500 dollars US for the carbon fiber trim, is that what you paid?
Old 11-12-2020, 12:47 AM
  #34
ac320's Avatar
S550e
Originally Posted by SilverArrow44
I purchased the steering wheel and airbag on Ebay. First I determined which parts I needed and searched for those specific part numbers. Found the steering wheel in mint condition, but then ran into some issues with the airbag. The first one I bought was an obvious counterfeit/rebuilt unit which I returned for a full refund. Eventually found the correct one that was also unaltered. Did the installation in my garage and it took about 30 minutes total; including disconnecting and reconnecting the battery.
Do you mind providing the part number for the airbag and a link to the ebay seller for it? I'm in the process if swapping my steering wheel out now and don't want to get a counterfeit / rebuilt one. Thanks!
Old 11-12-2020, 11:39 PM
  #35
SilverArrow44's Avatar
W222 S550 4Matic and Jeep Wrangler Rubicon
I have a black airbag with gray stitching and the Mercedes part number is 000-860-98-00-7J20. The link to the honest seller who sold me a non-deployed airbag is here. I won't share the info of the guy who sold the rebuilt airbag that I immediately returned for a refund, but be sure to ask for pictures of the actual bag that you'll receive and inspect them thoroughly. The mounting tabs of the two halves of the airbag are single use, so if they look mangled as if someone obviously tampered with it, don't use it. Also, there are packaging and warning labels covering some of the tabs. If the labels are gone or damaged, don't use it. Also, the wire harness and it's plastic loom should be present and unaltered. Finally, don't be afraid to ask if it's rebuilt. Apparently some body shops are comfortable installing rebuilt airbags, but I made it clear I wasn't.
Old 11-13-2020, 02:09 AM
  #36
ac320's Avatar
S550e
Thanks for the info...your link to the honest seller is a seller that I was looking at as well. They have a black with gray stitching for sale now and I'm considering just getting that one. My interior color is crystal gray/seashell gray so I think I may have a hard time finding an airbag in that color.
Old 11-25-2020, 03:00 AM
  #37
Greeksneak's Avatar
SL63 AMG; S63 AMG
So is your new wheel from an S Coupe? Do you have the part numbers for the wheel and airbag? I am wanting to do the same thing. I have the poplar wood trim but those numbers would lead me in the right direction. Thanks!
Old 11-25-2020, 04:13 AM
  #38
pb39374's Avatar
2010 E350 4Matic sedan
Here it is.
do you happen to have a picture of this steering wheel when it was still installed in your car?
Old 11-25-2020, 09:23 AM
  #39
E55Dimon's Avatar
E63S
Revotechmotorsports on Instagram have been doing it for years for all older models 👍
Old 11-25-2020, 09:26 AM
  #40
madkow70's Avatar
e-mail me direct? dj.kim@digitalconsultants.org
Old 11-25-2020, 09:51 AM
  #41
madkow70's Avatar
Old 11-25-2020, 02:37 PM
  #42
LAWYER2's Avatar
15' W222
That wheel looks good. Anyone have an updated link for the ebay parts needed, the other link doesn't work.
Old 11-25-2020, 04:16 PM
  #43
madkow70's Avatar
that steering wheel is for sale now. I took it off when I got a different car.
let me know if you are interested.
Old 11-25-2020, 11:40 PM
  #44
Were you asking about my part numbers? If so, they're copied below. Please note that's for a black leather steering wheel with walnut, heat, and lane keep assist. The airbag is black with gray stitching. The W222 was offered in many steering wheel and airbag combinations, so I started my search on https://www.mbonlineparts.com/ and looking up "steering wheel" to identity the part numbers and then searching Ebay for those numbers. There are some instances in which part numbers have been updated or superseded, but that at least got me close. Of course, double check with the seller that the item is as described and has the options that you need.
Steering Wheel
001-460-24-03-9E38
Airbag
000-860-98-00-7J20
Old 11-26-2020, 06:16 PM
  #45
Greeksneak's Avatar
SL63 AMG; S63 AMG
I couldn't find any reply with info on what eBay seller you purchased your "Coupe" style sport wheel and airbag. Can you please provide this information? Thanks!
Old 11-26-2020, 10:49 PM
  #46
pb39374's Avatar
Thanks - I actually have W212 that would look good in since I have the same color combo. Just not sure if I can get it to work in the W212. Think I would need an airbag and decoder from somewhere
Old 11-27-2020, 01:13 PM
  #47
E55Dimon's Avatar
E63S
I’ve been running this setup for 3 years in my w212 2014 E63s. No issue on w222 either. Revotechmotorsports on IG chip it and of course swap the airbag. Night and day, touchpads work.
Old 11-28-2020, 01:06 AM
  #48
pb39374's Avatar
thanks - I’ll reach out to Revotech
Old 11-28-2020, 11:19 PM
  #49
Greeksneak's Avatar
SL63 AMG; S63 AMG
Thanks for replying, twice! I missed it the first time. I need to do some research. If I needed the walnut I would surely buy yours but I need poplar.
Cheers!
Old 11-29-2020, 12:05 PM
  #50
ephico2real's Avatar
2023 EQS 580 Pinnacle Trim. 2015 S550 4Matic - OE tuning, 2014 E350, 2014 GLK, Sold: Volvo XC90
Are you still trying to sell the steering wheel? Will it work on 2015 S550 W222 with heat and vibration?
Quick Reply: S550 Steering Wheel
