S-Class (W222) 2014-2020
Apple iOS Beta Progam
Old Sep 13, 2019 | 09:32 PM
steinjr's Avatar
Veteran: Army
2015 S550 4MATIC
Any of you part of the Apple IOS Beta program and running iOS 13?
Bluetooth streaming works fine, but music will not play through either media port. The ports recognize my phone, but when streaming music, both ports say activating, but never activate. Then a message states no files.
Anyone else having this issue?
Old Sep 16, 2019 | 02:51 PM
steinjr's Avatar
Veteran: Army
2015 S550 4MATIC
Bump
Old Sep 16, 2019 | 03:34 PM
RoseyPSU's Avatar
2018 s560 4matic
I'm on iOS 13.1 PB 3. No issues at all with Car Play, however I have an '18 and I think that was the first year to use Car Play. I'll see if I can play music through a port without activating car play and get back to you....
Old Sep 16, 2019 | 04:06 PM
steinjr's Avatar
Veteran: Army
2015 S550 4MATIC
No CarPlay for me. Just Bluetooth and 2 media ports.
Thanks for taking a look. Much appreciated.
Old Sep 18, 2019 | 09:56 AM
S_W222's Avatar
Current/Last 5-years:GLS;G70;Alpina B8;X7;Accord. Sold:X7,TeslaS;S560;S550,X5;530e;L.Navigator;LS460
am running IOS 12.4.1 and it works fine, I know that this might not help as you are running another IOS version, however I've had some issues recently but I was able to fix it by trying to connect to another phone and immediately cancel it before it connects, then go back and select your phone again and activate auto-connect feature. It should work fine as long as you don't connect the Command system again to another phone. Once you do this, you'll have to repeat the process. It seems to me more like an iPhone Bluetooth compatibility issue cause it only happens with my iPhone after my wife uses her Android but works fine with Android almost all the times!
I really wonder why MBenz don't offer an annual update to the command system.
Old Sep 19, 2019 | 04:40 PM
steinjr's Avatar
Veteran: Army
2015 S550 4MATIC
Dealer found an update for the command unit and everything works now. 😀
Old Sep 19, 2019 | 05:02 PM
S_W222's Avatar
has anything changed in the command system after the update? any extra nicer features or anything you noticed? in other words, does it worth asking for the same update even if we have no issues with the current version?
Old Sep 21, 2019 | 10:20 AM
steinjr's Avatar
Veteran: Army
2015 S550 4MATIC
No changes to the user interface that I've noticed.
