S-Class (W222) 2014-2020
Garage opener works only a week
Old Sep 27, 2019 | 01:49 PM
Robert Sorensen's Avatar
2005 S55, 2018 S63
I have a 2018 S class and has programmed the garage opener to open my garage.
The problem I'm seeing is that after roughly a week (or it could be after a number of activations) the garage opener is no longer capable of opening the garage and to make it work again I do need to reset the opener and reprogramming it again.
My wife as a 2016 GLA and her garage opener has worked flawless for ~2-3 years.
Has anyone experience this issue? Or know how to fix it?
Could this be a defect in the actual hardware in the car?
Old Sep 27, 2019 | 01:53 PM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
I would reprogram one more time. If it does not hold the code I would take it to the dealership.
Old Sep 27, 2019 | 01:58 PM
2005 S55, 2018 S63
Well - I have reprogrammed it several times under the assumption that I perhaps didn't do it exactly as described.
Old Sep 27, 2019 | 03:36 PM
Warehouser's Avatar
2023 S580 Selenite
Had this happen, ended up being the garage door opener was maxed out on learned codes. After programming and using the last car (like your 2018) it kept bumping off the previous learned car. Once that car used the opener, it would bump off the last one and had to start over again. Needed to wipe ALL learned vehicles and remotes off of the opener and reprogram each item one last time. Never a problem after that.
