Removal of rear spoiler on S560
It seems I will end up with a spoiler whether I like it or not! On a leased car I understand that I must return it as I got it, but does anyone have experience removing the spoiler on an S560? Is it taped or bolted or both? Will there be paint damage?
3M taped to the trunk. No bolts or holes in the trunk. Get some robust fishing line and run it under the spoiler to cut the 3M tape and then get some goof off to remove the residue from the tape. Keep the spoiler for when you turn the car in and re attach it with more 3M tape. Very simple to do.
when you remove it there is a possibility that the paint underneath is damaged bc it was mounted when the paint was fresh. Use a heat gun and fishing line like stated.
16 E550 Cab, 2003 Ram bright red crewcab 4x4 we call Clifford :)
heat gun, very much so or even a blow dryer... and go slow with the line... if it's warm enough it should go thru easy...
If there is wrap place nearby they will be able to remove pretty easy as well...
the things I love and hate equally about where I live. So I’ll keep that in mind for sure.
