Vibration around 65-90!
Hey guys just picked up 2014 S550 45k miles from carmax. One owner.
The car is excellent! However, when I cruise around 65-90 especially around 85 I can feel the car vibrate so bad thorugh the seats and the center console. Is it the guibo that needs to be changed?
Car sat there for 1 week and they just replaced the brakes and balanced the wheels. However, the issue is still there. Not sure if they techs there are good enough to find the source of the issue.
Perhaps check the wheels to make sure none of them are bent. I remember I had a shimmer at higher speeds which was likely not felt at lower speeds because of the tire giving just enough cushion. Take it to an independent shop (not a dealer) and give them $50 to check all four wheels to make sure theres no degree of bend. I bet that's the problem. If it is - they can either repair the bend or at worst case scenario you'll have to purchase a new wheel (but it's likely they can repair)
hyperion667 (10-19-2019)
MTrauman (10-15-2019)
![](https://staticssl.ibsrv.net/autocomm/EvoM/fcotmicon.gif)
Received 3,399 Likes
2012 CLS63
GL!
