S-Class (W222) 2014-2020
Howling noise from the front
Old Dec 27, 2019 | 07:50 PM
NF204's Avatar
S63
Any ideas what is making my car - S63 with 4matic - howl infrequently?
Car is OEM and happens on both summer and winter tires but typically when turning although has started to happen when I drive in a straight line as well.
It only happens at low (<15mph) speeds.
I see lots of posts about bearings or differentials noises, but typically these noises are constant as you drive. My howl is infrequent and hard to replicate.
I feel it is coming from the driver side, and you can feel the vehicle reverberate slightly as well.
Dealer cannot figure it out. No signs of anything rubbing or damage.
Old Dec 27, 2019 | 09:24 PM
chassis's Avatar
2017 GLE350 4MATIC
If you believe the noise is infrequent and not related to vehicle speed, engine speed or throttle position, it must be caused by something with intermittent operation.
Be very precise about ruling out tire noise over certain paving surfaces. This week I drove on some very fresh macadam (asphalt) and my 30k mile tires were singing loudly. Some road surfaces create strange sounds with tires of various designs and condition.
Other possibilities, each can be ruled out using systematic testing and observation:
- brakes/ESP system
- power steering, not sure if this vehicle has electric or hydraulic power steering
- air suspension
- climate control - a/c compressor or blower
Old Dec 28, 2019 | 02:41 PM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
https://youtu.be/QAkRqs_0usc
Question, if you do not move the steering wheel at all, does the sound stop? I had a very similar problem and it was the steering wheel linkage. It got progressively worse over time.
For smiles and giggles, when it happens again while turning, stop and just put it into reverse while leaving the wheel in that position. Also, when it happens, throw the car into Neutral. Just to eliminate and narrow down some more options.
Old Dec 28, 2019 | 08:41 PM
gregorynp's Avatar
2022 GLS450
I heard a strange sound today. I did remove the front license plate bracket today
Old Jan 10, 2020 | 08:11 AM
NF204's Avatar
S63
I think you're right, as a separate dealer thinks it is related to the steering rack ... hopefully the MB dealer will be able to fix it.
Old Jan 10, 2020 | 09:31 AM
places's Avatar
No more MB:(
Definitely steering related.
Old Apr 28, 2020 | 12:36 PM
GMBALL's Avatar
S63 COUPE M157
I have been experiencing exactly the same noise on my 15 S63 Coupe. I could replicate it every time I wanted to. After an investigation of a technician I have been told that it comes from CCB brake rotors and it has something to do with their alignment.
My front CCB rotors have been replaced and the noise “almost” disappeared. Now, it comes only occasionally and is not as loud.
It definitely has something to do with the brakes. I wonder, do you also have CCB on your S63?
Old Apr 28, 2020 | 02:36 PM
NF204's Avatar
S63
Great point, yes I have CCBs. They ended up replacing the steering rack, and the howl is still there so I think you're correct.
Old Apr 28, 2020 | 06:17 PM
Katie22's Avatar
18 AMG GTC and 22 F150 Limited. Past owner 16 Maybach, 17 Brabus Smartcar, 06 Ford E150, and 22 G70
Sounds like the car is related to the airwolf helicopter.
Old Apr 29, 2020 | 02:23 AM
Nice Ride's Avatar
Its not the steering rack. It is a steering linkage. I will try to post the repair they did ( And, NOT covered under CPO ). It will get progressively worse if it is the same problem I had. It will only happen when you move the steering wheel and most noticeable at slow speeds <30
Old Apr 21, 2024 | 12:01 AM
PUKBenz's Avatar
2011 E350, 2014 ML63 AMG
OP, did you ever resolve this? If so, what did it turn out to be?
Old Apr 21, 2024 | 05:03 AM
George A.'s Avatar
Mercedes S550
Check the adjustments for the 6 round airflow vents on the dash. The little silver knobs, of which there are 4, adjust the airflow through these vent. I found that a low to medium adjustment setting causes a whistling or singing sound, caused by the airflow. If it starts to sing, I turn the knob to full off. Give it a try.
Old Apr 21, 2024 | 02:34 PM
PUKBenz's Avatar
Hmmm… I really don’t think this noise has anything to do with the climate control/vents.
Old Apr 21, 2024 | 03:22 PM
waterzap99's Avatar
S550 V8, CL600 V12, SLK32 AMG
Can always get something like the ChassisEAR. Its microphones you put around the car. So can really hear what is going on and where it is coming from.
Old Apr 21, 2024 | 04:53 PM
TripleDown's Avatar
2014 S63 2010 ML350 Bluetec 2009 SL550
It's the brakes ...had a Bentley that did this exact same thing. You can lightly touch the brakes to see if it goes away.
It's a harmonic resonance similar to running a wet finger along the rim of a wine glass.
Harmless ...ignore it.
Old Apr 23, 2024 | 10:37 PM
HAILERS2's Avatar
Presently 19 S560 SEDAN, 2014 XK, SOLD GLE 450e
The howling on my S560 is the dang cooling fan coming on when I don't think it should. Saying it's 71 degrees F outside and I drive three miles to the store and back, All under 45 mph and the dang fan comes on howling like a banshee. Yes, it is iintermittent but imho should never have come on under those conditions I know it's a variable fan, yes indeedy, but this is ridiculous. My S560 Coupe never, ever did this non sense. Just ranting. It has little to do with the original posters complaint.. Sue me.
