Replaced Front Pads
18 AMG GTC and 22 F150 Limited. Past owner 16 Maybach, 17 Brabus Smartcar, 06 Ford E150, and 22 G70
I did not have to replace the rotors since they were NOT warped and within thickness tolerance. SO my pads are different than your car since I have AMG calipers on my car from the factory. TRW is an OEM supplier and TRW is actually stamped on the caliper of my AMG GTC. So I brought TRW pads. Your pad for the front of your car is TRW model TPC1630 and you can get them from a variety of sources. Summit racing has them for 41 dollars at https://www.summitracing.com/parts/t...AaAtIcEALw_wcB
If you need rotors you might check a site called Autohaus as well as others.
PS be sure to check your rears as well. MY rear pads went before the front. Someone here explained that the distronic uses the rear to bring car back into lane for lanekeeping so that would explain why they went out first.
Katie
Katie
Katie
Katie
Sorry Nice Ride I forgot about that place. I will remember from now on.
PS Nice Ride I do good well researched work. NOT shade tree work.
You can make it the topic of discussion at the dinner table tonight so you don't forget.... They Take Back Used Oil..... Bonkers but True....
