advice on front grill damage 19 s560
i have α brand new Mercedes OEM front grill for sale. $800 shipped.
Install is easy and no calibration is require.
You do not need new rubber gasket to fit the 2014-2017 preface S class including the S63. What you will need is to change the front camera “ bracket “ as you can see from this video which is also from α preface S class ( S63 ) that I had to purchase separately to complete the install:
Again if this grille is to be install on α preface S class, you will need the pictured camera bracket.
If it’s for α +2018 and up S class which is the exact OEM grille I am selling, the bracket is not needed.
The reason α preface S class will need the camera bracket is because the preface camera/bracket sits on α different height as the +2018 S class as you can see from the video.
You will not need to any recalibration of the camera. It’s plug and play weather it’s for α preface or facelift S class.
PS. If you look at the attached video, you will see the difference between the prepare grill and facelift grille.
Hope this help.
i assume i will have to replace the grill if i want a perfect fix anyone know how much that runs for?
secondly any clue what i could do to temporarily cover up the chrome scratch/scuff? i know the black plastic behind is cracked too but thats harder to see so just covering the chrome would be great while i wait for my fix
https://youtu.be/0DUJP9qhVYo
Hope this help.
No top gaskets:
The short ( red ) camera bracket from the preface 2017 and older S class has the shorter bracket while the +2018 W222 S63 sedan:
