W223 full reveal (Ugly?)
People will get used to it.
M-B will tweak things in the LCI/facelift.
Life will go on.
COVID will be a thing of the past.
I like the exterior but need more and higher quality photos to fully evaluate the interior.
I think a lot of this is coming from BMW's own concepts: https://www.bmwusa.com/concept-vehicles/concept-i4.html
From an engineering point of view the MB V6 is an example of actually making a silk purse from a sows ear. Point being the I6 is more befitting a car of the S Class caliber and is more in line with classic Mercedes Benz lineage.
Sometimes it's not the engine that's causing the vibration as it could well be an associated drivetrain component or part of the hybrid system. I'll cite two examples from personal experience.
When MB went to the 9G which is a marvelous trans, the transition to the rwd models in the S's created no issues, but when it went into the AWD S models ie the 550 coupes something that was modified in the AWD driveline created a vibration at idle that was not present on the 7G versions (I know I had both a 16 and 17 at the same time). The transfer case was redesigned for the AWD in MY 17+ at the same time the 9G went in, and it may have very well had something to do with the rougher idle. I was working closely with the MBUSA Rep and he with MB in Germany on this for a while, and we tested several S550 soupes together from both MY's, the 16's (including mine) were so smooth you couldn't tell they were even idling, but every 17 (non AMG) had a vibration/resonance at idle. If one did not have the previous model with the 7G they most likely would not even know to realize the difference, but if they did or had a RWD sedan too, it's easy to notice. After doing my part for several months trying to help allowing MB to use my 17 as a guinea pig, they tried many things to correct the issue which proved unsuccessful and I sold my 17 for a new 19 BMW M850XI (fabulous automobile, butter smooth, well built, and a rocket). The rep stayed in touch with me for sometime thereafter as we struck several common chords, and he indicated since most customers were oblivious to the issue and since the 4.7 was being replaced by the newer 4.0 he was hoping it would be addressed during the transition, but sadly it was not (I was offered an 18 to try and get back to them and the issue persisted). The MB rep retired shortly thereafter so I'm not sure if the TC was ever updated.
The next example was with our 2017 Audi Q7's 3.0, it was also butter smooth with a supercharged V6, and the new 3.0 turbo 2020 we ordered which is a partial hybrid setup, was displaying a rough idle as were all those we tried. I have no idea what the exact cause was/is, but I'd bet it's the new engine's semi-hybrid setup. Again, if one didn't own the previous version they most likely would not notice unless they were the discerning type.
So with all that said, I'd bet the I6 is supersmooth on its own as they inherently are, but the added hybrid components may be causing the lack of refinement (for lack of a better word) you have experienced. It's truly as shame for MB to finally move back to I6's, and other components diminish the utter smoothness they display.
