S-Class (W222) 2014-2020
Command Unit Needs Replacement
Old Jul 12, 2020 | 08:20 PM
schack's Avatar
2014 S550
Apparently the “Command Unit” or “Control Unit” has failed in my 2014 S550 (46000 miles). The dealer wants $6000 just for the part alone. It is part #2229005108. I have looked at rebuilt parts and they are less money but state “without premium audio”. My car has the Burmester 3D premium audio system so I am not sure if they would work. Anyone had any experience with something like this. There is a chance my after market extended warranty will pay part or most of this but the whole thing is very frustrating.
Old Jul 12, 2020 | 08:32 PM
hyperion667's Avatar
2012 CLS63
I would, by all means, try to get the warranty involved! GL to you, sounds very frustrating!
Old Jul 13, 2020 | 07:39 AM
MBNUT1's Avatar
2010 E350 4Matic
Thank you for reporting this failure. Very concerning.....
Old Jul 13, 2020 | 09:11 AM
places's Avatar
No more MB:(
Big number. Try and get that warranty involved. Good luck!
Old Jul 14, 2020 | 08:11 AM
Katie22's Avatar
18 AMG GTC and 22 F150 Limited. Past owner 16 Maybach, 17 Brabus Smartcar, 06 Ford E150, and 22 G70
Have they tried to do a RESET on the head unit. I can say that my head unit on the Maybach and the GTC both locked up ONE time. Both simply needed a reset and all has been well ever since. For the Maybach the reset involved holding the CD eject button for a period of time that of which I cannot remember.
Katie
as far as if the part will work. I would suggest fireing up a copy of EPC and check the parts on a standard s class and then plug in your VIN number as see if the part number is the same. I have a suspicion that the head unit is the same and that it only feeds the amps....... assuming the head unit is the same part number and you install it in your car I am going to suggest it will probably need to be mated to you car with a Mercedes Scan tool.
Old Jul 14, 2020 | 09:23 AM
schack's Avatar
2014 S550
The first thing they tried was a software update and I was told this could take up to 3 hours. I waited for 2 hours and they came in and said the part was bad. The service manager contacted the after market warranty company and since it is such an expensive part the warranty company must send out an "inspector" to look at the car before they decide if I am covered. In the mean time I can drive the car but none of the functions of the Command center screen are available. The cars A/C works but I cannot even determine what temp. I have it set at. The center screen constantly displays the message "Bootloader Active".
Old Jul 14, 2020 | 09:33 AM
2012 CLS63
We're all hoping for the best OP, don't see how they could say no! At least you can drive your car with this issue, if it wasn't drivable.....that would be lame!
Old Jul 15, 2020 | 03:40 PM
OnlyGerman's Avatar
Too many german broads
Look at used if no warranty coverage.The audio system has nothing to do with it if it is programmed to the car correctly. Avoid the dealers crazy price. Who is your warranty, you should be able to figure out if it is covered or not. it may not be "new" but may cover used parts if covered at all. I hope you have coverage for this. Definitely a rare failure.
Old Jul 26, 2020 | 05:12 PM
schack's Avatar
2014 S550
Just wanted to follow up on my post concerning the faulty control unit. We finally got the report from the 3rd party Inspector and the Warranty Company has agreed to cover the repair with some limitations.
They will not cover the $6000 OEM part from Mercedes. They will, however, cover a remanufactured part, which they will supply. They stated that if I wanted the Mercedes OEM part it would cost me an additional $1700. So I deduce from this that their supplied part is worth $4300. I did ask about the warranty on the OEM part vs. Rebuilt part and they stated the warranty was the same. Both are warranted for 2 years.
The labor was also in dispute as the Dealer said the repair would 3.5 hours and according to the Warranty Company’s “tables” this repair should only take 2.2 hours, a difference of 1.3 hours. The “extra” 1.3 hours would be my responsibility and at $160 per hour cost me $208. There would also be a deductible of $100 per visit, which would be my cost as well.
So in summary: My Cost: $308 Warranty Company: $4652.
I am inclined to accept this. The Dealer has been very helpful with this, even providing a loaner car free of charge for the duration. Also, the loaner is a 2020 Mercedes C350 with only 473 miles when I drove it off the lot, which impressed me even more.
Obviously the repair has not been made yet, and there could still be issues ahead. I will keep everyone informed as to the final outcome.
Old Jul 26, 2020 | 05:24 PM
valley_isle's Avatar
2023 C43, 2016 S550 4MATIC, 2021 GLE350 4MATIC, 2021 GLC 300 4MATIC
Command Unit Failure
I had this happen a few weeks ago on my 2016 S550 with about 55,000 miles. What’s strange is that I went in for the NAV update and after the update, everything was working, except that the upcoming streets and highways were showing on the NAV screen as red question marks. Took the car back in and they found Control Unit failure. In my case, CPO warranty covered OEM part and labor. I still find it concerning that this unit failed on a 3.5 year old car with only 55k miles in my case.
Old Jul 26, 2020 | 07:09 PM
2012 CLS63
Glad to hear some assistance arrived! If you can swing it, sounds like it may be a good deal. And with the other perks you mentioned sounds like the dealer is behaving pretty well. Make sure to get some doughnuts too Thanx for the update
Old Jul 26, 2020 | 08:37 PM
MBNUT1's Avatar
2010 E350 4Matic
Spooky to hear of two failures of this nature.
Old Jul 26, 2020 | 08:38 PM
2012 CLS63
Talking
2 out of how many?
Old Jul 26, 2020 | 08:47 PM
places's Avatar
No more MB:(
Makes you think, what else is around the corner? Lots of tech.
Old Jul 27, 2020 | 08:21 AM
OnlyGerman's Avatar
Glad it is going to be taken care of. And some people here think extended warranties are a waste of money....
Old Jul 27, 2020 | 08:52 AM
MBNUT1's Avatar
2010 E350 4Matic
2 out of how many?
How many are on this forum?
Old Jul 27, 2020 | 11:23 AM
2012 CLS63
Is that a trick question?
Old Jul 27, 2020 | 04:59 PM
MBNUT1's Avatar
2010 E350 4Matic
No it represents the sample size of 2 failures
Old Jul 29, 2020 | 06:39 PM
chaswills1516's Avatar
2014 S550
Who’s the Extended Warranty Company
[QUOTE=schack;8117138]Just wanted to follow up on my post concerning the faulty control unit. We finally got the report from the 3rd party Inspector and the Warranty Company has agreed to cover the repair with some limitations.
I wish you the very best. Keep me posted.
Old Aug 3, 2020 | 07:20 AM
schack's Avatar
2014 S550
Wanted to post a hopefully final update on the command unit replacement. I got the car back a few days ago with the rebuilt command unit. Everything is working fine and the repair seems to be a success. My final out of pocket cost was $308 and the warranty company cost was $4652. The warranty initially cost $2500 for 3 year "gold" coverage. The warranty (or VSC as they call it) is from NESNA (Nissan Extended Sevices of North America). I still have over 2 years of coverage left so obviously it has paid off.
Old Aug 3, 2020 | 07:23 AM
2012 CLS63
That's great news, glad it's done Now back to driving
Old Nov 3, 2023 | 03:49 PM
Ndeltorto's Avatar
2014 550s limited
I’m having the same issue right now!
I am having the exact same issue right now quoted $6000 for the dealer replacement part found one on eBay for $899 now out of stock found another on eBay but not sure it will match $1100 crazy with this fail. My vehicle has 27,000 miles on it 2014 550 S Checking with a re-manufacturer in Canada that may be able to rebuild the unit… This seems like a crazy lot to go through for a Mercedes product
Old Nov 3, 2023 | 05:18 PM
BenzNinja's Avatar
Former Vendor
Just let me find you right device from ebay and i will code, unlock and adapt it on your vin
potentially eligible for the Golden ticket too with this
Old Nov 4, 2023 | 09:06 AM
schack's Avatar
2014 S550
See my posts earlier in this thread to see how the issue was resolved for me. It's now more than 3 years later and the replacement Command is working flawlessly.
Old Nov 4, 2023 | 09:12 AM
vinflouen's Avatar
2019 W222 S560 4Matic/2025 Yukon Denali
Benz ninja can fix this for you if its a software issue.
he can find you a proper unit that will work and code it to your car.
find benz ninja.
