S-Class (W222) 2014-2020
W222 fan
Old Aug 10, 2020 | 10:58 AM
Andylee's Avatar
W222
W222 fan
Hi has any one had a problem with their W222 main fan coming on really loud. It seems to happen when I’m in traffic, the engine temp is 90 degrees. I was wondering if it’s anything to do with the gearbox overheating as it only happens after I’ve been in traffic( up and down the gears ) this happens at at all ambient temperatures. The car sat for a few months and only started to keep the battery functioning. I’ve had the gearbox serviced but that hasn’t worked. Just wondering if it’s something simple it happens with or without the air conditioning on🤷🏻‍♀️It never happened before only on hot days but know anytime the gearbox has a lot of use.
w222
Old Aug 10, 2020 | 12:48 PM
Andylee's Avatar
W222
it’s been plugged in a few times and they say nothing wrong but it’s very loud like a jet turbine sometimes but never when they are looking at it. 🤷🏻‍♀️As I say it never happened before but happens all the time now 🤬. If I drive it normally. Short distance up and down the motorway it’s ok it only happens when the gearbox is working harder than normal. 🤔
Old Aug 10, 2020 | 01:55 PM
konigstiger's Avatar
'71 Pinto
VIN?
Old Aug 10, 2020 | 02:13 PM
Andylee's Avatar
W222
You need the vin number?
Old Aug 10, 2020 | 02:22 PM
hyperion667's Avatar
2012 CLS63
Noobs
Old Aug 10, 2020 | 02:23 PM
'71 Pinto
Reluctant to provide VIN, MBUSA released a service campaign for MY 2014-2015 222 requiring no cost replacement depending on fan production date, capacitor in control unit intermittently malfunctions.
Old Aug 10, 2020 | 02:46 PM
Andylee's Avatar
W222
Sorry. New to this. WDD2221322A286274
Old Aug 10, 2020 | 03:03 PM
2012 CLS63
Just breakin' 'em a little OP good luck to ya!
Old Aug 10, 2020 | 04:09 PM
'71 Pinto
Originally Posted by Andylee
The car sat for a few months and only started to keep the battery functioning. It never happened before only on hot days but know anytime the gearbox has a lot of use.
As mentioned capacitor in the radiator fan control unit “could intermittently malfunction” this will not always store fault code(s). If there are no codes first have battery/charging system checked afterward you may need to take a wait and see approach. If budget allows you can proactively have fan (part # 0999060512) replaced but this is your call.
File Type: pdf
Old Aug 10, 2020 | 04:24 PM
Andylee's Avatar
W222
Thanks for this. Much appreciated
Old Aug 10, 2020 | 05:56 PM
trustz's Avatar
2010 W204, 2014 W212, 2015 W222, 07 SAAB 9-3, 2016 AMG GTS
I have a similar issue, please check my VIN WDDUG8CB2EA006608
Thanks a lot!!
Old Aug 11, 2020 | 08:38 AM
'71 Pinto
Originally Posted by trustz
Vehicle shipped from factory 8/20/13 need to have dealer check VMI to see if VIN is included, see attachment.
File Type: pdf
Old Aug 12, 2020 | 06:23 PM
trustz's Avatar
Thank you so much!!
Old Sep 28, 2022 | 12:34 PM
kunzy80's Avatar
S550
w222 Fan issue
Dear konigstiger
can you please help me by looking if the recall would apply to my vehicle
here is my Vin number -
Vin number
WDDUG8FB1FA127871
Your help would be greatly appreciated as always
Old Sep 28, 2022 | 12:52 PM
'71 Pinto
Same if applicable: https://mbworld.org/forums/s-class-w...ml#post8129909
File Type: pdf
Old Sep 28, 2022 | 02:13 PM
kunzy80's Avatar
S550
Thank you konigstiger
Dealer states
car is out of warranty
Is that accurate?
Old Sep 28, 2022 | 02:37 PM
'71 Pinto
If 2015050004 is applicable to your VIN Service Campaigns & Recall Campaigns do not expire even out of warranty / unlimited mileage.
