S-Class (W222) 2014-2020
Lowering Issues?
Old Feb 10, 2021 | 10:48 PM
Kirill98's Avatar
Tesla Model 3, Corvette C8
Lowering Issues?
I've seen multiple comments here saying lowering will cause your shocks to blow. How accurate is this?
Old Feb 11, 2021 | 03:38 PM
Wolfman's Avatar
Super Moderator
It depends. Lowering a car lightly (up to 3/4") will have no impact on the suspension or ride quality. When you lower more, ride quality will be impacted but I can only imagine an actual risk of blowing out the struts when a car is slammed.
There are a couple ways to lower the car either via links and ELM's (electronic lowering modules). Older modules only lower the car until a pre-detemined speed (usually 35mph) and raise it back tock height which is nice as ride-quality is perfect and no alignment is required but I believe that most OBD modules use fixed height settings like links...
Old Feb 12, 2021 | 02:11 AM
Kirill98's Avatar
This lowering module seems interesting:
https://www.amazon.com/Mercedes-Suspension-Lowering-Control-AirMatic/dp/B07C7G3J13/ref=sr_1_2?dchild=1&keywords=mercedes+lowering+module+w222&qid=1613113645&sr=8-2 https://www.amazon.com/Mercedes-Suspension-Lowering-Control-AirMatic/dp/B07C7G3J13/ref=sr_1_2?dchild=1&keywords=mercedes+lowering+module+w222&qid=1613113645&sr=8-2
I Plan on doing this with a 2017 s550. I am just unsure if airmatic is only equipped on 4matic? I came across a post on here from a user stating that.
Old Feb 12, 2021 | 01:56 PM
Wolfman's Avatar
Super Moderator
Originally Posted by Kirill98
This lowering module seems interesting: https://www.amazon.com/Mercedes-Susp...3113645&sr=8-2
It should work on all W222 S-Class models. I still have on of these laying around from our E63s; they work as advertised. I paid $300 for that one so prices have really increased...
These modules are great but more limited than other installed modules. No show stoppers though. Modules must be plugged in for every change, no individual wheel adjustment, no speed-dependent lowering. No selling after changing cars due to VIN-lock.
Good luck!
