Amber Turn Signal Fitted + Rear Fog Light
![](https://cimg5.ibsrv.net/gimg/www.mbworld.org-vbulletin/817x1345/579918e4_afee_4f0b_a54c_4ee5433f1eda_95291ace4bda4cac8226977026c3e0673e3a5421.jpeg)
Original Turn Signal (Flashing the Brake Light as Turn Signal)
![](https://cimg3.ibsrv.net/gimg/www.mbworld.org-vbulletin/577x539/7f80e938_d69d_42d0_adb8_1f5cba8ff574_63e638b1ba073557ce050b9ac4bf1b770d5aac75.jpeg)
Amber Turn signal (separate from Brake Light)
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/1338x640/d636993d_b733_4515_bd66_079b5fcf4569_aed6a3e2a66801a44a734c6f8e29e09a43fa2647.jpeg)
Rear Fog Light added.
Tried searching various forum but not too much information, so I decided to share it here in case anyone is interested.
This is a 2020 S560 but should be the same for 2018 and up or even pre-facelift models from 2014.
What’s needed;
For Amber turn signal;
EU taillight
One extra wire from taillight to rear SAM for new turn signal
Coding to disable brake light from flashing as turn signal and enable amber turn signal.
For Rear Fog Light;
EU rear diffuser (below rear bumper)
NO need for car with AMG package because rear fog cut out is there.
The rear fog light itself
Light switch with rear fog light button
Connection to rear fuse for power
Connection to rear SAM for control
Coding to enable rear fog light (symbol shows up on instrument cluster when rear fog is turn on)
When rear fog light is turned on, headlight will activate Enhanced Fog Light function with wider beam for better illumination to the side of the road.
(Enhanced Rear Fog Light requires Full EU Multibeam LED functionality)
EU Multibeam can be activated on US spec headlight by coding or plug and play OBD tools available online.
Additionally fitted;
EU headlight (same operation but without US side marker) coding to enable intelligent light system setting menu in car
Tow Away Protection Sensor and coding to enable original setting menu in car
Interior Motion Alarm and coding to enable original setting menu in car
Mounted original warning triangle inside trunk lining
Original safety vest and EU first aid kit added for EU compliance.
What’s needed;
EU taillight
For Rear Fog Light;
J. Brown (01-15-2022)
