S-Class (W222) 2014-2020
2016 S550 Back Seat Charger Issue
Old Jun 24, 2021 | 09:01 AM
debfun's Avatar
S550
I have a 2016 S550 4Matic and have had intermittent issues with the back seat charger working. I have had it into the dealership and they cannot get it to reproduce issue as it is very sporadic. It also comes apart on a regular basis as shown below in the pic. Thoughts on things to check, suggestions for dealership to check?
2016 S550 4Matic Charge Port Rear Seat
Rear Seat Charging Station in my 2016 S550 4Matic
Old Jun 24, 2021 | 11:01 AM
konigstiger's Avatar
'71 Pinto
DIY (if so inclined) or dealer suggestions:
- Check/replace fuse f461 (15A) @ trunk fuse panel
- Remove rear panel to inspect housing & check connections
- Replace socket part # 0008206251 & housing 2218200209 (cover trim can be reused)
Old Jun 24, 2021 | 12:03 PM
debfun's Avatar
S550
Thank you, I will try this. and thanks for the pdf, that is VERY helpful
