S-Class (W222) 2014-2020
Drive train vibration
Old Jul 25, 2021 | 02:49 PM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
Originally Posted by Donnymac
Thank you sir. Given my pothole history, that makes 100% perfect sense. Should’ve thought of that myself.
I thought the op said the vibration is worse at a stop light. A bent wheel will not cause this.
Old Jul 25, 2021 | 03:40 PM
Donnymac's Avatar
63 Falcon vert
That was Vinnybenz OP, not me.
Old Jul 25, 2021 | 04:01 PM
Jud Chapin's Avatar
Yep, senior moment…Sorry
Old Aug 3, 2021 | 05:00 PM
vinnybenz's Avatar
2013 GLK350 2016 GLE400 2019 E450 Wagon 2018 S560 2021 E450 AT
Update: 93 octane made no difference than 91.
Now aside from my OP re: stoplight idle vibration/noise, the more irritating thing is the 'groaning' rumbling vibration that also comes thru the steering wheel which occurs in typical block by block city driving at 30mph/50kmh (1100 rpm) with a slight step on the gas pedal to maintain speed with traffic. Every time you slightly step on the pedal, the grumbling occurs. You think I could get it to happen at the dealer, not a chance, so pissed off.
Anyway, got another dealer app't since it's been happening the day after the 1st visit last Thurs. Any ideas folks? My 2019 E450 wagon didn't have this issue.
Old Aug 3, 2021 | 05:18 PM
Donnymac's Avatar
63 Falcon vert
Two thoughts:
In your garage with the motor off, rock the steering wheel. Generally you can hear worn bushings, if any.
Have a proven Indy suspension shop inspect the front suspension system.
Old Aug 5, 2021 | 08:58 PM
vinnybenz's Avatar
Went to the dealer today and he suspects the engine mounts. He has a 2018 S560 in for the mounts due to what seems to be the same prob. So I'll wait to see if that car drives better with the new mounts.
Also ordered a new battery since my morning voltage before starting was 12.30 volts.
Old Aug 5, 2021 | 09:37 PM
  #32
Donnymac's Avatar
63 Falcon vert
Have the trans mount swapped also. It too wears out.
Old Aug 5, 2021 | 09:42 PM
  #33
vinnybenz's Avatar
Thx Donnymac, will pass on your suggestion to the SA, he's a pretty good guy.
Old Aug 5, 2021 | 11:08 PM
  #34
MBNUT1's Avatar
2010 E350 4Matic
My guess is it will fix both issues.
Old Aug 5, 2021 | 11:50 PM
  #35
vinnybenz's Avatar
What do you mean? What is the ''both issues" and what will fix them?
Old Aug 6, 2021 | 12:31 PM
  #36
MBNUT1's Avatar
2010 E350 4Matic
"Now aside from my OP re: stoplight idle vibration/noise, the more irritating thing is the 'groaning' rumbling vibration that also comes thru the steering wheel which occurs in typical block by block city driving at 30mph/50kmh (1100 rpm) with a slight step on the gas pedal to maintain speed with traffic."
Old Aug 6, 2021 | 02:00 PM
  #37
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
An '18 with 22k miles needing motor mounts? That seems quite a young age for mounts, interested to see if that turns out to be the fix ...
Old Aug 6, 2021 | 05:29 PM
  #38
Donnymac's Avatar
63 Falcon vert
Originally Posted by Denis Osullivan
You have a bent rim that is causing those 75/80 vibrations. Balancing the tires will not correct it. Been there , done that.
You are exactly right. Was my Indy shop this morning. All 4 bent. Two fronts way worse than the rears.
He reminded me it was not a Jeep.
Old Aug 24, 2021 | 11:02 AM
  #39
vinnybenz's Avatar
Well I'm still waiting for the dealer to replace the engine mounts. He has replaced the trans mount but taking a day and a half seems long to replace engine mounts. Does that seem right to you?
Old Aug 24, 2021 | 12:03 PM
  #40
Donnymac's Avatar
63 Falcon vert
Engine mounts take more time. Could also be parts or labor issue. I would not be concerned yet.
Old Aug 24, 2021 | 07:05 PM
  #41
MB_downunder's Avatar
2013 SL350 (R231), 2024 EQE350 4matic SUV (X294)
We have an E Class cabriolet and a S Class. At only 20,000 miles the E Class needed new engine mounts. The car would shake like crazy at idle. It was replaced under warranty. They also did the transmission mount. The mechanic said he sees it a lot, ever since “auto stop/start” came along.
I have since programmed Auto Stop/Start to be turned off by default when starting. Did this on both the E Class and my S Class. I believe Auto Stop/Start is the biggest scam ever. It is used for auto manufacturers to get a lower emissions scores, which they need to comply with legislation. However, the savings and benefits to the consumer is nothing, maybe $50 a year in petrol? I don’t see how these vehicles are designed to start 50-100 times a day without some significant wear and maintenance costs. The “emission savings” is also redundant given all the old worn parts are now in land fills.
Old Aug 24, 2021 | 07:18 PM
  #42
vinnybenz's Avatar
I tend to agree with you too!
Old Aug 24, 2021 | 08:01 PM
  #43
W205C43PFL's Avatar
That, and you are not really saving anything and actually wasting gas to restart the engine unless your car has been stopped for more than 8 to 10 seconds at least. Stop and Go traffic most of the time, does not make sense to have this on.
Old Aug 24, 2021 | 08:03 PM
  #44
vinnybenz's Avatar
many talk about 'programming' the default but never supply or explain the software
Old Aug 24, 2021 | 08:24 PM
  #45
W205C43PFL's Avatar
I guess because it takes time for them to figure it out so they charge for it. There are start-stop "memory" modules sold around to achieve this. They are those ones where you connect to your vehicle's ODB port. Although they aren't exactly cheap.
Here's an example:
Amazon Amazon
Old Aug 24, 2021 | 08:29 PM
  #46
W205C43PFL's Avatar
There is a "free" approach which is to unplug one of the fuses but that affects more than the start-stop, it affects the alternator which can lead to damages in the long term (your car will rev higher on idle too) hence why it is "free" and not free. (I haven't find the post talking about which specific fuse yet and it too differ from different model of MBs, so probably don't recommend this either way)
Another approach would be just muscle memory when starting the car and hitting the start-stop button or just switch to individual with the setting to auto-stop disabled chosen.
Edit: Forgot this method too exist, although I don't know if it safe but I will share it here anyways but please proceed with caution:
https://mbworld.org/forums/c-class-w...tart-stop.html
Last but not least, disconnect or alter the auxiliary battery (highly not recommended)
Edit 2:
Found a cheaper option: https://www.midcityengineering.com/device/eco-off/ (in USD though)
Old Aug 24, 2021 | 09:57 PM
  #47
Just ask. I purchased the OBD module from Ebay. You provide them your VIN number, and they send you a small OBD port module that you plug into the OBD port located above your brake peddle. Then turn your car on (without starting engine). It’s all automated and takes about 1 minute, you get a Success notification on the Comand display. Then you remove the OBD module, and never use it again!
Now, every time you start your car, ECO (or Auto Stop/Start) is off. If you want it on (for some reason), simply push the ECO button again. Press again to switch off.
Yes, I think its expensive for what it is (mine on eBay was approx USD$120), but its one less hassle to think about. And I hate auto stop/start that much.
I’ve noticed in some interior photos that the ECO (Auto Start/Stop) button is heavily worn. I’m guessing they press it every time they start their car to switch it off.
Old Aug 25, 2021 | 11:31 PM
  #48
Donnymac's Avatar
63 Falcon vert
Interesting correlation! Makes sense,
Old Aug 30, 2021 | 04:42 PM
  #49
vinnybenz's Avatar
Dealer finally got the engine and trans mounts in another 2018 560 and I went for a test drive in it 'on their lot' only. The steering wheel vibration was minimal. However since we didn't actually do a city road test, I'll never know if it solved the prob until I check back with the Ser Adv and see if the customer was satisfied.
Then while I was there, the mechanic went with me to see if I could get my vibration issue to display itself with me driving. NOT A CHANCE! I'm so frustrated cause all the way there, the problem was more than evident.
One noticeable observation, in the last couple weeks waiting for the dealer to do the repairs, I have discovered that shutting the ECO off, the problem almost disappears! What the heck is going on here. As I pressed the ECO switch off, i could sense a slight transmission adjustment.Totally baffled.
Old Aug 30, 2021 | 06:10 PM
  #50
Donnymac's Avatar
63 Falcon vert
If its the mounts, it will only get worse.
I am ordering ECO delete as mentioned earlier by W205C43PFL.
