MY2018 - COMAND refuses to play music from USB drive
Now it does nothing, apart from a message stating that "Reading USB device...". I've left it a couple of hours and it's not changing. I've formatted and renamed the drive, even put the files into a Music folder; still nothing; I can't make COMAND treat this as a new USB drive and try to read all the files again. The drive is readable from my PC..
At some point, I removed the flash drive from USB 1 and attached it to USB 2. The first time I did that, the "reading" message didn't go away and it didn't seem to recognise that I reattached the device. The next day I did the same and whilst it DID recognise that I removed the USB drive, it did not when I attached it back. I tried to reset it from the system menu but it didn't help (although I restored the backup I took right before the reset, so I don't know if some kind of a music database was exported as well).
Any ideas about what could be wrong? Is it the number of files? Is it the flash drive? Is my COMAND toast? Is there a reset approach that would work? Thanks!
Guess it's time for a warranty claim, disappointing considering how I pamper the car and with less than 3 months of ownership. I now wonder if there are other subsystems waiting to fail and I am a bit concerned since I've arranged a few weeks' worth of vacations and am going with the car.
Dealing with software is my day job and I cannot fathom how could that possibly be true. It's very uncommon for software to just get corrupted and start exhibiting erratic behaviour without a hardware reason, so I don't know. Usually if software "gets corrupted" it leads to crashes but even that tends to be caused by hardware reasons (e.g. bitrot, bad sectors on a drive etc).
I didn't lose many settings which is weird, since a reset usually... resets everything, including the settings. I did however notice that the volume changing pop-up became gray compared to blue that it was before. I am not sure what to make of this and if it means that there was a version upgrade/downgrade.
