S-Class (W222) 2014-2020
Oil Leak
Old Aug 8, 2021 | 09:57 PM
604benz's Avatar
2015 S550V
Oil Leak
I have a oil leak at the bottom pulley on the front of the engine on passengers side, anyone know if this is a minor or major fix
Old Aug 8, 2021 | 10:29 PM
chassis's Avatar
2017 GLE350 4MATIC
Need more photos and diagnostic work. Need to find the source. If you DIY, remove the underbelly shields and look around with a bright LED flashlight.
A loose oil filter is an easy fix. A leaking front engine cover is an expensive fix.
Old Aug 9, 2021 | 12:00 PM
Bart-N3GQ's Avatar
Veteran: Army
2016 S550, 1995 E320, 1996 Jeep Grand Cherokee
As chassis said, a photo of the source of the oil leak is needed. You may need to wipe the surrounding area, then wait a bit to determine the source of the oil leak.
Old Aug 9, 2021 | 12:17 PM
Katie22's Avatar
18 AMG GTC and 22 F150 Limited. Past owner 16 Maybach, 17 Brabus Smartcar, 06 Ford E150, and 22 G70
That oil could be dripped from previous oil change. Just a thought.
