S-Class (W222) 2014-2020
Changing Stations
Old Aug 28, 2021 | 07:27 AM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
Changing Stations
Looking for the best way to navigate through the 200-plus channels on Sirius XM, other than shuffling up and down through all the channels ...
Let's say I'm listening to 80s on 8 and think, gee, I'd like to go jump to the 100-150 range. Is there a voice command I use to say "channel 100" ... ? Maybe set a preset for every 20 XM station numbers or so, like 20, 40, 60, 70, etc?
Old Aug 28, 2021 | 11:18 AM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
You can have an awful lot in the presets. I have like 20 Sirius channels in my presets and I just spin though them with the command wheel.
Old Jan 11, 2024 | 05:36 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
How do you set it up so that you only scroll through presets instead of all the channels?
Old Jan 11, 2024 | 05:54 PM
NbyNW's Avatar
Veteran: Navy
Various
Pretty straightforward…
Edit… it’s been a while but think once on the station you want, hold down the knob until you get a beep. Then repeat.
Old Jan 11, 2024 | 07:11 PM
I'm now in the habit of hitting the voice command button, and saying "Station Number". The system prompts me to enter the station number I want. Easiest method I've found.
I wonder if satellite radio with hundreds of channels existed in Europe when they designed the UI for this service. Surely the product planners realized users would want a simple way to navigate all that content. In our Honda we have satellite presets for every 30 or so stations. So when I want to go to 'Watercolors', I use the preset that takes me to station number 60, then tap my way up to 66.
Old Jan 12, 2024 | 04:56 PM
Top Answer: 1
I've saved 7 or 8 channels I like as presets so they are starred and are in the preset list, but they are spread out. What I want to do is be able to only "see" or "scroll to" saved channels, not every channel. I think I had this setup for terrestrial/local radio on my 17 S550, but I don't remember if I did it for satellite radio or not.
Old Jan 12, 2024 | 05:25 PM
NbyNW's Avatar
Veteran: Navy
Various
I’ve done it for satellite, after pushing the radio button on the console all I get are my favorites, then rotate the knob to scroll thru them.
And I rarely use satellite radio any more - I plug in my phone and go to my Apple Music playlists. Someone ^ mentioned Watercolors… I used to listen to that all the time. Yacht Rock also. Maybe I need to pull up SXM more.
Old Jan 12, 2024 | 06:34 PM
mercedesbuff's Avatar
'20 GLS450, '17 S550 Sedan
Yes, when I don't want to manually switch between presets... I use voice commands.
As long as you're already listening to SIRIUS radio, you just press the steering wheel voice control button and say "Station: The Blend" and it will tune to "The Blend." As long as you can remember the station name, you're golden!
I mainly listen to only these 5 channels, so I just have to remember the name: 80s on 8, The Blend, The Bridge, Classic Rewind, Yacht Rock Radio.
Good luck!
Old Jan 13, 2024 | 01:39 AM
BenzV12's Avatar
W212 FL
I guess I'm the only person who prefers USB over other media components
Old Jan 14, 2024 | 04:42 PM
sha4000's Avatar
S560 AIRMATIC
I also prefer to just pop a USB stick in for all my music.
Old Jan 14, 2024 | 08:16 PM
NbyNW's Avatar
Veteran: Navy
Various
Don’t USB sticks use MP3 music files? I have a memory card with tons of music plugged into the console just in case. My Apple Music is all downloaded as hi-res or lossless, so hopefully it sounds better on the fancy 3D sound system.
