S-Class (W222) 2014-2020
Fine Scratch Removal
Old Oct 5, 2021 | 11:41 PM
frostsdad's Avatar
2024 GLS450W4, 2016 S550 4MATIC (W222), 1972 350SL (R107), 2012 GLK350 (X204)
My W222 has designo piano black lacquer interior trim. I am the second owner. The exterior body has no dings, not a scratch! I am discerning when it comes to that and I couldn’t find any imperfections. The interior is almost as good, save some fine scratches near the start button and the sliding cover in the rear console compartment between the two rear seats (I have the Executive Rear Seat Plus package).
Any suggestions on a product to use on piano black scratches? I think I read on here to use the same cleaner/scratch remover that you’d use on a black lacquer piano. Thoughts?
Old Oct 6, 2021 | 06:19 AM
cfmistry's Avatar
15 S550 4Matic, 86 560SL
I do not know that you will remove them entirely, but I would start with the Novus 3-step system.
Old Oct 6, 2021 | 08:30 AM
1bad540's Avatar
s550 Diamond white amg pano
scratch x to start and see how that goes. Ive done mine a few times as the dealer has scratched it one more than 1 occasion.
Old Oct 6, 2021 | 09:13 AM
MichaelinChicag's Avatar
2019 S560 Sedan
A little off-topic, but related. The guy who details my cars suggested that I apply the same kind of protective film he uses on the exterior to interior surfaces like the piano black cupholder cover to prevent them from scratching. I have a couple of scratches to remove from mine first, so I'm interested in what people here suggest for that.
Old Oct 6, 2021 | 11:36 AM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
To do it right you really need to use a small rotary or orbital polisher and pad and tape it off, etc. Doing it by hand you will almost always introduce more scratches trying to remove scratches.
Old Oct 6, 2021 | 04:12 PM
W205C43PFL's Avatar
oops sorry wrong thread
Old Oct 9, 2021 | 02:48 PM
MBS63AMG's Avatar
2019 S560, 2022 Audi S8
Dremel makes a small circular buffer perfect for this. It comes with lock and loop pads that can be applied to the devices lock and loop pad. Be sure to use lite amounts of polishing creme and use towels everywhere nearby because it will sling the creme all over the place.
Old Oct 9, 2021 | 05:38 PM
SW20S's Avatar
2024 S580
Yep, thats exactly the tool I was thinking of. You have to be really careful though because you can burn right through the urethane clearcoat with that.
Old Oct 10, 2021 | 04:59 PM
MBS63AMG's Avatar
Yes. I forgot to mention that. In addition, the pads are only about 2" in diameter.
Old Oct 11, 2021 | 10:58 AM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
Unless you have experience with motorized buffing, I wouldn't suggest starting with this type equipment. When doing such a job, always start with the least abrasive substance. I would start with regular car cleaner/polish and if not successful, begin using very fine compound. I would try it first in an inconspicuous area. You don't want to make it worse. After compounding, polishing will probably be necessary and regular car polish should bring the sheen back. Without experience, I wouldn't use a motorized tool. Just my 2 cents.
Old Oct 11, 2021 | 11:49 AM
as.thompson's Avatar
Veteran: Air Force
S550C4, Porsche Cayenne
Jud, I agree with you it is best not to use a motorized buffer unless you are experienced with using it. But that raises the obvious question - how do those of us who do not have such experience gain the necessary experience? It's sort of a "you-can't-go-unless-you've-already-been" situation.
Old Oct 11, 2021 | 12:03 PM
Jud Chapin's Avatar
As they say, practice makes perfect. I would practice on something else first until you get the feel for it.
Old Oct 11, 2021 | 11:21 PM
Donnymac's Avatar
63 Falcon vert
With a microfiber rag, Acetone or lacquer thiner can work great on clearcoat scratches. If not to deep, chemical will feather the scratch and it disappears.
TRY TEST AREA FIRST!
Old Oct 12, 2021 | 05:02 AM
BenzV12's Avatar
W212 FL
I have not tested Acetone as scratch remover but thanks for the tips
Old Oct 12, 2021 | 07:59 PM
SW20S's Avatar
2024 S580
I would highly advise against that...
Old Oct 12, 2021 | 09:30 PM
Jud Chapin's Avatar
Me too...In fact there's a lot of suggestions in this thread that could do serious damage
Regarding the scratches, how fine are they? Can you feel them with your finger nail?
Old Oct 12, 2021 | 10:51 PM
Donnymac's Avatar
63 Falcon vert
Ill add my observation. I have seen clearcoat scratches caused by jack handles etc disappear in seconds. Will it work in your application, I have no clue.
Test it first.
Old Oct 13, 2021 | 09:49 AM
SW20S's Avatar
2024 S580
Also...don't be afraid to take it to a professional detailer and let them polish those out for you. They would probably do it for $150.
Old Oct 14, 2021 | 04:01 PM
2019 S560 Sedan
That's the best advice I've heard in this thread - yes, go to a pro. Better to risk a hundred or two to the detailer than to further damage that surface.
