S-Class (W222) 2014-2020
Best 19s for soft/quiet ride
Old Apr 17, 2022 | 09:12 AM
will_atl's Avatar
2020 S450 4Matic, 2022 GLS450 4Matic, 2015 C300
@mercedesbuff thanks for the reminder on tire pressure,I checked mine and they were not on the comfort setting 😱, so I let some air out and took a short ride. I probably need to get out on the highway to be able to gauge the difference.
Old Apr 17, 2022 | 10:14 AM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
Originally Posted by 2012 merc amg
I really like my Continental Pro Contact GX SSR's Run Flat tires. They ride fine and are quiet except on rough gritty pavement but I can live with it. I just replaced the rears at 27K miles, coulda got another 5K miles outta them and thats not bad for a rear runflat tire. The fronts I think I'll be able to make it up to 40K miles. On my E450 Wagon I have Michelin Primacy 3 tires and that car handles like a sports car with those tires, they are runflats too. I'm up to 19K on those tires and they are maybe 60 percent worn.
I had those and replaced them with the Primacy MXM4 non runflat. Those Continental runflats aren't bad, but the Primacy non runflat is definately softer and quieter.
Old Apr 17, 2022 | 04:47 PM
KingdomCometh's Avatar
S560
Originally Posted by will_atl
I can’t comment on the S Class but I had a similar experience to @Longi with Continental DWS06 on my CLS, I swapped from Pirelli P Zeros, and the DWS’ were definitely a louder tire.
I have Good Year run flats on my new toy, and I may move to NRF when the time comes to replace them, my wife’s ‘22 GLS450 rides quieter.
Fun fact: the new GLS’s have the foam in the tires for the quieter ride!
Old Apr 19, 2022 | 12:29 AM
Longi's Avatar
2019 S560 4Matic; 2021 GLS 450
That is an interesting fact. What tire brand is fitted on the new ones? This may help us making the GLS quieter/softer.
Another fun fact: loaded with 7 people and more baggage than reasonable, the GLS rode much better. Weight really helps. To the point that I suspect that the suspension's airbag are over-inflated for light loads, and therefore fairly harsh in day-to-day usage.
Old Apr 19, 2022 | 12:37 AM
S560
I’d try to get a Benz mechanic and talk to them directly about this so you can get the best out of that suspension tbh.
Old Apr 19, 2022 | 01:31 AM
2012 merc amg's Avatar
2018 S560
I'm really fine with the Conti Gx SSR's. I'm actually amazed I got 27K miles outta the rears, I'm fairly aggressive with the car and it's just rear wheel drive and nearly 500 hp and of course the tires are never rotated due to be staggered. I really think I'm going to get over 40K miles on the front tires the way they look now at 27K miles that is if I don't get a sidewall bubble, I was almost tempted to tell them just to throw fronts on with the rears as I've got a 1500 mile drive coming up in a couple of days and would hate to get stuck somewhere with a bad tire, but so far the tires seem great knock on wood. I think I'll just stick with them in the future, the run flat feature is nice it saved me once on my wagon a few years ago when something metal cut a hole in the sidewall and I was able to drive the car 50 mph 50 miles back to the dealer and get a new tire. I sure wouldn't be up for changing out a tire on the side of a busy highway.
Old Apr 19, 2022 | 09:15 AM
  #32
will_atl's Avatar
Our GLS450 has Pirelli Scorpion Zero All Season (Rear 315/40 R21, Front 275/45 R21), I have no idea if they are foam filled or not. I just looked at the outside of all 4 tires, and I don't see anything to indicate that they have the Pirelli Noise Cancelling System (PNCS), I have no idea if they should be marked as such or not?
Old Apr 19, 2022 | 09:43 AM
  #33
S560
If you look on TireRack and scroll through the tires for the GLS, including your sizes, the Pirelli PZ4s come in the regular and the PNCS form for that tire size. It also utilities the Conti SportContact 6, a version of which has the ContiSilent addition for your tire sizes. The Scorpions do indeed come with PNCS, per TireRack. There’s a version with and one without, but the one with should be what yours has.
The foam tires for these brands are size-dependent and only for specific vehicles. You’d need to read through and look for the ones that have the foam tech specifically. Only way to verify yours does is to check the interior of the tire but that involves taking it off the rim.
Old Apr 19, 2022 | 11:16 AM
  #34
SW20S's Avatar
2024 S580
Reports of how effective that foam is are mixed...
Old Apr 19, 2022 | 03:55 PM
  #35
S560
Only one way to find out for me and that’s buying them, but after hearing such good things about the Pirelli P7 AS3+ I don’t think I’m wasting my money on some runflats with foam
Old Apr 19, 2022 | 04:01 PM
  #36
Googsy's Avatar
S350d
Just trying to interpret picture 2 which shows tyre pressures from the fuel cap.
So if the above states for normal load 36 front and back.
it then says if driving below 100mph to lower by 4 psi . Meaning values should be 32 front and back for normal load and less than 100mph ?
Old Apr 19, 2022 | 05:14 PM
  #37
SW20S's Avatar
2024 S580
Read reviews from Tesla drivers (the foam tires come standard) when they switch to non foam tires...
Old Apr 19, 2022 | 05:18 PM
  #38
S560
Are they good or bad?
Old Apr 19, 2022 | 05:24 PM
  #39
SW20S's Avatar
2024 S580
They say they really don't hear any difference losing the tires with the foam
Old Jul 23, 2022 | 02:11 PM
  #40
Longi's Avatar
A belated update on tires for my 2019 S560
Purchased a set of Extreme Contact DWS06 Plus in 19’’. Ride improved somewhat, but the tire is loud on motorways and thumps on expansion joints. Not really an improvement.
Bit the bullet and purchased a set of 18’’ wheels with PIRELLI P7 AS PLUS 3. Ride is excellent and noise suppression is much improved. Got a good offer from tirerack.com, all up about $1,800.
I’m happy with this setup. Wheels are pretty much the same design as my original 19’’ AMG. The wheels do need spacers though, look odd given as they are recessed in the arches.
Thanks for the advice above.
Old Jul 23, 2022 | 02:24 PM
  #41
will_atl's Avatar
@Longi I wasn't sure that I wanted to hear that the 18's are better, even though it makes sense! I am on 20's and I just love the look, but I think that they impact the ride quality. But interestingly it only seems to be me that notices, I recently got my fronts rebalanced (road force) and I have been playing around with the tire pressure, as I was getting a lot of vibration & feedback on the highway, like I say my wife didn't notice it when driving, but I did. Right now I seem to have things where I want them, but here in Atlanta the temps swing so much on a daily basis that 34psi today could be more or less tomorrow!
Old Jul 23, 2022 | 03:19 PM
  #42
2018 S560
Yep the Pirelli p7 pluses are great. I run them on my Chevy pickup and got over 40k miles on the last pair. As soon as my Michelins primacy tires are gone on my E450 wagon I’ll be putting those on it. I’ve got the 19 inch rims aftermarket ones. 19 inch seems like a good compromise between looks and ride.
Old Jul 23, 2022 | 09:40 PM
  #43
kafklatsch's Avatar
All Cars Lost To Hurricane Isaac (W124 E420 revived - added 88 Allante 14 S550, 17 S63
I hated the pirelli MOE tires that came on my car... im spoiled with high expectation for smooth quiet ride in an S
I purchased my first non-michelin tires for my MBs (michelin only since 1994).. i bought bridgestone quiet tracks
very smooth, good absorbsion over bumps and dead quiet on my S. I love these although it was tough to go away from michelin... but i just did not like the pirelli fun flats.. and wanted quiet smooth riding tires
I too purchased the compressor and repair slime OEM.. little more costly than aftermarket kits, but i purchased the GLS listed compressor... it fills a totally flat large wide amg wheel i had in my garage in 85ish seconds ( if i recall)...from totally flat.... i had to upgrade the fuse by 5 amps in my trunk receptacle because the gls compressor has higher output.
Old Jul 24, 2022 | 08:56 AM
  #44
kafklatsch's Avatar
I Hate aftermarket swaps ...however.... that looks fantastic... excellent taste and choice.. wow... ive come back to the thread just to look again
Old Jul 24, 2022 | 07:17 PM
  #45
SW20S's Avatar
2024 S580
I am extremely pleased with the Pirelli PZERO All Season Plus tires I put on my AMG 19s. I've taken a couple road trips, and the tires ride great and are dead quiet. The P7 AS Plus (II and 3 included) are great tires, I ran them on my Lexus but I wouldn't go to 18s.
