S63 Factory Tires
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
S63 Factory Tires
I know this is not the S63 forum but it seems to be more active. Anyone know which version of the Michelin tire came from the factory. I have the 20" Forged 10 spoke wheels. Car has Michelin PS3 MO and the Merc dealer said that this car was supposed to come with RFT tires.
2019 S560, 2022 Audi S8
Thanks MB, I purchased this car from a broker and I suspect someone decided to swap the tires with 9K miles for a set that is much more used thinking I would not notice. If the 2019 came with Michelin PS3 MO non RFT tires then I am probably just stuck with what I have.
I do not believe the AMG W222 S-class comes with run-flat tires.
Many owners that did get RFTs (in non-AMG W222s) switch them out to non-RFTs for the notable improvement in ride quality, less noise, less likelihood of bent wheels.
The following 2 users liked this post by cfmistry:
aeggroup (01-26-2022),
Streamliner (01-10-2022)
I don’t think the S63 came with RF tires.
Superpop how do you like the 3D sound after having a modified non 3D sound car? I am borrowing a similarly optioned S63 for the weekend and surprisingly unimpressed with 3D, as my 550 with non 3D has a JL sub and amp which sounds great.
'94 SL600,'05 SL600,'06 S65,'07 E63,'14 E63S,'09SL600 all sold, ‘15 S65,‘18 E63S,'17 SL65, '17S65Cab
The S63 and S65 did not have RFT's. There should be a mobility kit under the trunk floor that includes an inflator and tank of "goo."
The tire size, load range and speed rating posted by Konigstiger are correct. However my S65 has the PS 4S tires with an MB specific designator in the tire code.
I bought a brand new 2017 S63 and it came with non-RF tires. It chewed up tires very quickly and in the past I've always gotten at least 30K miles on a set of staggered tires, regardless of non-RF or RF tires. The S63 would go through them in less than 15K miles. I decided to always keep the suspension in "sport" mode and it doubled my miles for a set of tires. Alignment was checked and the toe-in was checked, camber, etc. and at the end of the day, my trick worked. Keep it in Sport suspension mode all the time.
